Calipers and tyres?
Bike Chat Forums Index -> The Cycling Forum Goto page Previous  1, 2, 3  Next
PostPosted: 12:48 - 16 Jul 2020    Post subject: Reply with quote
kramdra wrote:
Where can I buy decent mineral oil at a non extortionate price?
Baby oil is mineral oil.
https://www.youtube.com/watch?v=63VIuPiX3CA
kramdra
PostPosted: 14:35 - 16 Jul 2020    Post subject: Reply with quote
Also looks like bicycle bleed nipples are just screw holes with an oring seal, there is no nipple that seals on a tapered seat? I am not quite sure how that works as some air will get in when swapping the nipple for the sealing screw.
https://cdn.shopify.com/s/files/1/0269/4791/1754/files/mineral-oil-boiling-points.png?v=1571391068
Interesting.
To swap dot4 would likely need new seals and hose, or just strip and clean?
No I am not using baby oil, tho it would be easy to check its boiling temp..
PostPosted: 19:27 - 16 Jul 2020    Post subject: Reply with quote
It's a totally sealed system. You fit a funnel thing into the hole so you can brim it with oil, bleed all the air out then put the screw in. No reservoir as such.
I'm not sure if the seals will be an appropriate material for DOT4.
My AVID Juicy brakes use DOT4.
PostPosted: 19:54 - 16 Jul 2020    Post subject: Reply with quote
The seals in mineral oil systems will be unhappy if DOT fluid is put in the system.
For bleeding them you'll need either the Shimano bleed funnel or a syringe with the same fitting that Shimano levers use.
Air won't get in when you refit the screw to the caliper after removing the bleed syringe and hose.
There'll be appropriate bleed kits available if needed (like this https://www.totalbleedsolutions.co.uk/clarks-mountain-bikes one) and there'll be many guides on youtube showing how it's done.
kramdra
PostPosted: 21:03 - 16 Jul 2020    Post subject: Reply with quote
Got this seemed light, narrow, with some padding.
https://i.postimg.cc/YC5vbLFM/IMG-20200716-201733.jpg
Even with it fully back, I feel like I want another 2 inches adjustment.
Jumping up a small kerb my chain jumped off the front sprocket and stopped the bike dead. Ive had simillar jumping down a kerb with chain jumping off the rear. What is the cause? Only small kerb, was going slow.
PostPosted: 00:18 - 17 Jul 2020    Post subject: Reply with quote
Is the chain too long?
Easy-X
PostPosted: 01:30 - 17 Jul 2020    Post subject: Reply with quote
Looking at the bike photo it's a standard long armed derailleur. Chain doesn't look overly long but it's a bit hard to tell from the angle.
Best to check the bike over on the biggest cogs, front and back to get the length right and also take a look at the chain line from there and with the smallest cogs (i.e. lowest gear front, highest gear back) not that you'd probably use such a combination but just for worst case scenario.
Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
PostPosted: 10:27 - 17 Jul 2020    Post subject: Reply with quote
Also have a close look at the chainrings for hooking, it could be picking up on a hook when you back-pedal and lifting the chain off the teeth.
PostPosted: 10:38 - 17 Jul 2020    Post subject: Reply with quote
If the chain is jumping off then the first thing to check is that the H and L screws on both the front and rear derailleurs are set correctly.
Easy-X
PostPosted: 12:41 - 17 Jul 2020    Post subject: Reply with quote
Hahaha! Good shout, I adjusted the very same thing on my granddaughter's bike only this last week. I'd plumb forgot; this Covid business is a right mind-fuck. Then again I may have imbibed a large quantity of mind erasure fluid* in the intervening period Wasted
*Lager
PostPosted: 18:37 - 17 Jul 2020    Post subject: Reply with quote
Don't forget when setting you're the H and L screws, wind the barrel adjusters in completely then you can take up all that slack by tensioning the cable at the derailleur end.
kramdra
PostPosted: 20:40 - 17 Jul 2020    Post subject: Reply with quote
While the front brake is good improvement, is it worth the 10-15 quid to upgrade disc from 160mm to 203mm? Floating for a few quid more.
Thanks I will need to look this up later but probably right.
Did 25km on new seat. Arse is not sore but doing 60 miles will be a challenge. I do want to be doing 60 mile+ round trips soon.
This it seems will work, but was unnessasary. I unloosened the brake hose, measured and cut, jammed the new compression nipple and screwed it back up with a gentle pull on lever. Feels identical to before, without a massive loop of hose. I am starting to like this mineral oil stuff.
sickpup
Old Timer
PostPosted: 19:59 - 21 Jul 2020    Post subject: Reply with quote
Check the manual for the forks. A lot of forks have a rating for discs as they exert leverage and if an over sized disc is used can cause damage.
Without taking the piss too much have you rebuilt the forks yet? they probably needed it about 7 years ago regardless of whether the seals are blown.
Easy-X
PostPosted: 01:06 - 22 Jul 2020    Post subject: Reply with quote
I'd go with the same as a woman motorbike: slightly bigger up front Wink
180mm would probably not be too much of an upgrade (with regards to fork stress) and easy enough to do. Did me okay on my stupid >30mph eBike.
kramdra
PostPosted: 23:38 - 31 Jul 2020    Post subject: Reply with quote
The seat is a massive improvement now that my fat arse is used to it. I did upgrade the discs and put sintered pads, much better.
The chain jumping has been a pain. Right when I need power, bang, no power. Decided to replace, picked up new chain and rear sprockets and idlers, Btwin branded from Decathlon. Looks like I need to order the front set, but new dont have much more meat on the teeth. What to get?
Rear sprockets only have minor wear but the old chain is missing 3 rollers, that was the cause.
https://i.postimg.cc/fWvGmxTW/IMG-20200731-171107.jpg
This any good?
https://www.decathlon.co.uk/triple-chainset-7-8-9s-mtb--id_8523921.html
kramdra
PostPosted: 16:21 - 04 Aug 2020    Post subject: Reply with quote
Could use some help chosing the front sprocket/crankset. I want durable, hardened steel teeth, not this shite..
https://i.ebayimg.com/images/g/MFYAAOSwE-Vef4Pj/s-l1600.jpg
Old one
https://i.postimg.cc/ZKq5dt9f/IMG-20200801-150128.jpg
PostPosted: 20:34 - 04 Aug 2020    Post subject: Reply with quote
How much are you spending?
kramdra
PostPosted: 00:05 - 05 Aug 2020    Post subject: Reply with quote
Thirty pounds?
PostPosted: 00:27 - 05 Aug 2020    Post subject: Reply with quote
Marginally over budget but if spending about £30 on a chainset then I'd probably go for one of these (44 / 32 / 22 and 175mm). https://www.tredz.co.uk/.Shimano-FC-M371-Square-Taper-Chainset_63608.htm
What cassette and chain did you buy?
kramdra
PostPosted: 09:30 - 05 Aug 2020    Post subject: Reply with quote
That is for 9 speed? I need 8.
I got a Decathlon Btwin rear and chain, but they didnt have cranksets.
I was looking at this
www.ebay.co.uk/itm/Shimano-Altus-Chainset-M311-MTB-Square-Taper-with-Chainguard/264737041269
I cant see any fronts that say hardened teeth. If they are not, quite expensive per mile.
PostPosted: 11:03 - 05 Aug 2020    Post subject: Reply with quote
9 speed chainrings are completely fine with 8 speed chains.
I think the reason you can't find any that say hardened teeth is because they don't exist and that's because they're not necessary.
Depending on what length cranks you want and what size chainrings you want and that eBay listing for the FC-M311 only has one variant available, the rest are available from Tredz. https://www.tredz.co.uk/.Shimano-FC-M311-Altus-Square-Taper-Chainset_74973.htm
The FC-M371 will be slightly better quality than the FC-M311 however it's going to be the cheap Decathlon chain that wears first.
kramdra
PostPosted: 12:35 - 05 Aug 2020    Post subject: Reply with quote
I thought 9speed+ had tighter spacing, which will not line up with my 8 speed derailer and shifters?
I do want the same chain rings 28-38-48. A swap to 44 would have me spinning very fast, which I am not good at.
I would say it is nessasary, how long would you expect new chain and sprockets to last?
PostPosted: 12:44 - 05 Aug 2020    Post subject: Reply with quote
Your eight speed rear derailleur doesn't come into it. Mr. Green
Go for 28-38-48 if you're happy with those on your old chainset. Smile
How long should the chain, cassette and chainring last? Ages and ages and ages and ages. It will be the chain that's the weak link, no pun intended, but that's only going to reduce the lifespan to ages and ages and ages. Wink
kramdra
PostPosted: 12:58 - 05 Aug 2020    Post subject: Reply with quote
The front deraileur and shifters are expecting the sprockets in a certain place. If the set have a narrower spacing, it wont line up.
Ages and ages if I dont ride it? Ive done under 500 miles on this bike, it was used but dont think it had done much when I got it.
PostPosted: 13:02 - 05 Aug 2020    Post subject: Reply with quote
I do wonder how long rollers had been missing from your chain.
We were busy telling to set up the limit screws on the derailleurs, to check for worn teeth on the chainrings and things like that when it turns out that your chain was literally falling apart. Laughing
It's a good example of the importance of thoroughly checking your bike over every so often. Although missing chain rollers is the type of thing that should be noticed when oiling the chain. Laughing
The last post was made 4 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.12 - MySQL Queries: 16 - Page Size: 135.67 Kb
