Petrol tank treatment
pdg
PostPosted: 19:12 - 07 May 2024    Post subject: Petrol tank treatment Reply with quote
Got a bit of rust inside a petrol tank, would very much like it to not get worse...
Any recommendations for an internal treatment/sealant/goop that actually might work and can cope with ethanol?
Ta muchly.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 19:19 - 07 May 2024    Post subject: Reply with quote
POR15. Full 3-part treatment which has a degreaser, etch and the paint itself. Scrupulously follow the instructions. Particularly with regard to totally and thoroughly drying it before putting the paint in.
Be warned, it does NOT come off stuff once it's set so don't spill and if you do, remove it before it dries. A mate did a trailer chassis with it then wanted to weld stuff on some years later. Couldn't get it off, not even with a wire brush in an angle grinder.
Don't be tempted to just use the paint without the pre-treatment.
pdg
PostPosted: 20:07 - 07 May 2024    Post subject: Reply with quote
I've heard mixed reviews on POR15, but that was 20+ years ago and it's highly likely they just tipped out the petrol and dumped the por in...
I do know someone that used a competing product - after a couple of months it looked like there was a screwed up carrier bag inside his tank where it had totally separated - that's the sort of thing I'd also quite like to avoid.
I may experiment with chemical rust removal first too - back in the days of 4* I would've left it at that but modern E* fuel is so hygroscopic it's almost certain to rust again quite quickly (especially as it's Chinese steel).
So, rust removal too - is evaporust really better than vinegar?
PostPosted: 20:24 - 07 May 2024    Post subject: Reply with quote
I've seen some remarkable results with deox-c.
pdg
PostPosted: 20:27 - 07 May 2024    Post subject: Reply with quote
Thumbs Up I shall investigate.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 16 - Page Size: 46.21 Kb
