Author |
pdg |
pdg World Chat Champion
Posted: 11:01 - 09 May 2024 Post subject: |
MCN wrote: |
Suk Me.
You horrible little man.
It's 2024.
Whitworth is 1884.
Devised by Joe Whitworth.
It is NOT a motor vehicle size.
It is a size that may be found in one or two areas of a motor vehicle.
Your obvious display of non-awareness suggests that you believe everything is universally understood.
In addition:
You maintening your Cock Measuring Campaign on here is noted.
If you are not satisfied with your dimensions, may I suggest that you seek help/advice from an appropriate mental health professional.
Member Disphoria. (Thinking one is 'Bigger' than what's the case)
I hope that helps. |
So, seeing as you edited I feel the requirement to reply.
Who rubbed sand in your vagina this morning?
If I thought it was universally understood I would've said something along the lines of "dur, everyone knows xyz", but I didn't.
Instead, I helpfully implied that if you're holding a spark plug with a 10mm thread, chances are you need a socket matked "10mm S P." (there are different standards in use, but the ones most people are likely to come across follow this convention).
Complaining it's an old convention is a bit self important of you - do you bemoan how almost every M8 fastener in the world uses a 13mm hex, except when the Japanese decide to use 12mm or 14mm (often a mix of all 3 sizes) just because they can? Or how they thought "it'll be fun to grind the tip off this Philips screwdriver and introduce a new and incompatible standard that you can't easily differentiate "?
The fact that my renewed presence has made you feel so inadequate that you feel the need to personally attack me speaks more about you than it does about me.
Anyway, I'm off to enjoy the sun. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
Back to top |
stinkwheel |
Posted: 15:43 - 09 May 2024 Post subject: |
He's only bitter because he knows Whitworth is the original and the best.
You should sneak round his house and replace all his BMWs M5 torx-head bolts with 2BA cheese-heads. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
MCN |
MCN Super Spammer
Back to top |
pdg |
Back to top |
MCN |
MCN Super Spammer
Back to top |
pdg |
Back to top |
bazzaboy2010 |
bazzaboy2010 Two Stroke Sniffer
Back to top |
pdg |
Back to top |
