This what some folk pay good money for
WD Forte
PostPosted: 13:39 - 05 May 2024    Post subject: This what some folk pay good money for Reply with quote
Whilst repairing, servicing and tarting up the wee SH125 I removed the
Spy 5000 alarm supplied and fitted by WWS motorcycles for the
previous owner.
The remotes had long been lost and I decided it was best out of the way and if the next
owner wants an alarm they'll have a clear deck with no redundant wiring cluttering the
thing up.
There are various ways to plumb in an alarm and I wondered what I'd find
Scotchloks, crimps, solder, terminal blocks etc?
Nope, WWS motorcycles in Bristol had done their usual shabby work
and just twisted wires together and wrapped some tape over it all.
I'm told this cost him 3 times the value of the actual alarm itself
These are get you home bodges not in any way what you'd expect when you pay for a 'professional' installation.
I've done similar in an emergency and conciously bodged things for testing/experimenting
but not even a blob of solder on these permanent joints indicates their standard of work.
Main power take off
https://imgur.com/2YfzOX6.jpg
Link to remote starting
https://imgur.com/W1CnwQe.jpg
Side stand switch, more cut, twist and tape
https://imgur.com/Dd23nwP.jpg
bikers smell of wee
PostPosted: 17:50 - 05 May 2024    Post subject: Reply with quote
I had similar from MotoCal in Edinburgh when they were still on the go. They fitted an immobiliser to my brand new MZ. Only the second (and last) new bike I ever bought. After about 18 months it started occasionally misfiring or cutting out, culminating in it conking out entirely one hogmanay with no spark. After two days of searching and testing all the ignition componants on the pavement outside my brothers house, I eventually found a bit of PVC tape on one of the CDI wires which had no business being there. It had been cut then twisted back together and wrapped in tape. I can only assume they had been going to route it through the immobaliser then changed their mind (it would have been a good one, rendered the bike immobile).
This is one of several reasons why I have trust issues with motorcycle dealers and mechanics.
pdg
PostPosted: 18:26 - 05 May 2024    Post subject: Reply with quote
To be fair, twist'n'tape is a more reliable and long lasting connection than scotchloks (blue guillotine of death).
In order of preference for a repair or accessory fitment, weighted for ease and need of rectification, worst first:
Scotchlok/wire nuts - tied position.
Just tape.
Twist and tape.
Insulated crimps.
Solder and heat shrink (standard or adhesive lined)
Correctly sized bare crimps with adhesive lined heat shrink.
Replacement run of cable.
A friend was having indicator issues after a "repair" on an alarm installation on an FJ (iirc) - a smattering of scotchloks, a couple of wire nuts, a crossed connection or two - unfortunately I can't name the 'electrical specialist ' who did the work because I don't know it but there was certainly something special about him... Some people shouldn't be allowed tools, let alone be allowed to charge for using them...
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
MCN
PostPosted: 02:58 - 07 May 2024    Post subject: Re: This what some folk pay good money for Reply with quote
previous owner.
thing up.
Main power take off
Trading Standards need to visit.
Maybe a battery charger fire could happen.
sickpup
Old Timer
PostPosted: 20:08 - 10 May 2024    Post subject: Reply with quote
Is WWS the place that deals with all the Deliveroo drivers?
struan80
PostPosted: 20:29 - 10 May 2024    Post subject: Reply with quote
Scary stuff. It's difficult to get someone to trust. Thankfully my go to for bike issues is very professional Not cheap though. I would be lying if I said I hadn't done a splice by twisting the wires and a bit of electrical tape. Things were so much better back then. Laughing I used to be good at tinning.
WD Forte
PostPosted: 20:38 - 10 May 2024    Post subject: Reply with quote
Yes, this scoot was in there lot and I fixed manys a fuck up of theirs.
He told me they'd charge him £40 to read the fault codes but had no clue as what to do next and told him he'd have to book it into Fowlers
(High labour charges, long wait times) so he'd have to bring it to me.
I get that the Deliveroo riders wants to get stuff fixed ASAP and in town so they can keep earning, but I told him time after time to find another/better shop.
I think at first he thought I was just being a sarcastic foul mouthed
old bastard and maybe I am, but he's finally twigged and started using
a more professional bunch he tells me.
He told me Fowlers the main Honda dealers labour charge is £100 an hour with VAT
Ouch!
and Kellaway Motorcycles is £60 an hour
Both decent shops but damn, that's pricey
He took his Mobylette to a so called 'expert' who charges £50 an hour
who was unable to rectify a simple fault in the rear light.
It literally took me 2 minutes as I saw the feed to the rear light from the back of front one had been disturbed and used a finger and thumb to move it back into the correct position.
If it had been his mate trying to help out fair enough but
charging money for inept services is a piss take.
bikers smell of wee
pdg
PostPosted: 21:42 - 10 May 2024    Post subject: Reply with quote
At some point does it not become simply more economical to learn how to fix some stuff yourself, even if it means paying to take a course?
I just can't quite wrap my head around someone buying what is essentially an old shitter and then paying 50-100 an hour to have relatively simple jobs done, and oftentimes done badly. Not that it's an example of bad work, but the 50 my son just bought came with a receipt for having the indicators replaced - £10 for a set of mini indicators plus £79 to undo and then do up 4 nuts and 8 bullet connectors (I suppose I should be almost thankful they did actually use the connectors) - oh, and they would've had to unclip the seat too.
Maybe I'm just getting tight in my old age...
struan80
PostPosted: 22:19 - 10 May 2024    Post subject: Reply with quote
No your not getting tight, it's scarey and what main dealers want to charge you does my head in.
It's not that I'm not able to do things myself. (Engineer for over 30 years) It's just plain I can't be bothered and am only interested in riding the bloody bike. Very Happy
MCN
PostPosted: 23:09 - 10 May 2024    Post subject: Reply with quote
That's like Physician first heal thyself.
Many people have absolutely no interest in fixing things they need but have no interest in.
Have you worked the numbers on your own pension plan?
PostPosted: 23:23 - 10 May 2024    Post subject: Reply with quote
Haven't got one because much like with motorcycle shops, I think anyone offering that service will either fuck it up or fuck me over... Am I wrong?
MCN
PostPosted: 02:00 - 11 May 2024    Post subject: Reply with quote
I don't know.
I'm not an actuarial expert.
I think it's not as necessary today as finance is more open to lay people.
I was only suggesting that some areas of our existence require a degree of knowledge, training, study and more importantly, some interest.
Because one is interested ina particular subject and one may be proficient in all things involved with that interest, doesn't mean anyone can be as gifted just because they need to.
I want to be a billionaire but I'm not gifted in that department.
My skills are many such as, charm, wit, patience and generous understanding of the needs of others. Cool
And managing bcf posts on mobile app is testing all of my skill set.
pdg
PostPosted: 05:36 - 11 May 2024    Post subject: Reply with quote
I'm in no way saying that everyone should be an expert in everything, but...
Having at least an inkling of what's involved may just give you a fighting chance.
I need a roof, the roof I have leaks. Because I'm pedantic I know exactly why it's leaking and how to remedy the situation, but like buggery am I getting up a ladder - so I'm getting a man in to fix it. Because I've taken the time to do a little learning, I'm far less likely to be in the situation where some pikey charges me twenty grand to whack some silicone around a tile...
By changing the details slightly, that example could be used for many other scenarios.
Also, there are situations where it really is more economically viable to get things done for you - I charge more per hour than the majority of my customers earn themselves, but because I can do it faster and better than they can it works out in their favour (they give me say 2 hours of their earnings for an hour of my work, the same thing might take them 4 hours and be worse at the end). It may not be that I'm fantastic, but I have a practiced efficiency.
So, should everyone who operates a motor vehicle be able to rebuild an engine? Well no, if course not - but they should at least be capable of pumping up tyres, checking oil and maybe changing a bulb. They are of course free to choose to pay someone to do those things too, but they have no justification to complain about the price and they should also be able to spot when it's properly shoddy work.
(Oh, and yes I have analysed my pension - in a previous life I was a web publisher for a pension company and I did a bit of proof reading too, so I had an education through osmosis... For me, a specific type of pension plan works out better than life insurance/assurance and in the event of my demise there will be sufficient funds to cover setting me on fire, paying for at least 3 people to get mildly tipsy, and planting a tree.)
A100man
PostPosted: 08:01 - 11 May 2024    Post subject: Reply with quote
Never!
MCN
PostPosted: 08:43 - 11 May 2024    Post subject: Reply with quote
Many people do not give a flying fuk.
Understand this.
Many people don't even care how rain gets into their kettle.
They don't care.
pdg
PostPosted: 10:28 - 11 May 2024    Post subject: Reply with quote
Understand this.
They don't care.
Oh I understand it, and you know what?
That's absolutely fine really - less competition when society collapses. They'll simply die and get out of the way quite quickly. I'll have to put up with a couple of weeks hearing about everything being unfair while they struggle to open a tin of beans with no ring pull, but I can deal with that.
Until such time though, being willfully ignorant removes your entitlement to complain about price or quality of service.
MCN
PostPosted: 10:32 - 11 May 2024    Post subject: Reply with quote
pdg wrote:
Understand this.
They don't care.
Are you like this whenever you're outside?
Yer fkn hard work Pal.
pdg
PostPosted: 10:52 - 11 May 2024    Post subject: Reply with quote
I'm not allowed out often.
Ooh, but guess what? I deliberately purchased some E5 petrol last night (as opposed to picking up the wrong handle to fill my can). A whole 5 litres of it.
I was positively effervescent with excitement, bordering on shuddering.
A100man
PostPosted: 12:52 - 11 May 2024    Post subject: Reply with quote
Did you get 'chubbed'?
pdg
PostPosted: 14:21 - 11 May 2024    Post subject: Reply with quote
It was touch and go for a minute, not gonna lie...
Thankfully I managed to temper my excitement by purchasing some diesel fuel too.
blurredman
PostPosted: 18:05 - 11 May 2024    Post subject: Reply with quote
https://i.giphy.com/4LRkCWLi2MKOc.webp
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.19 - MySQL Queries: 17 - Page Size: 130.32 Kb
