Irn-Bru |
Irn-Bru World Chat Champion
Posted: 19:47 - 15 Jul 2018 Post subject: CarChatForum - Intake Air Leak Astra Derv |
I know a lot of you lot have old knackered cars like me, bikes rule after all but I still like my cars to actually work so thought I'd ask Car in question is a 2006 Astra 1.9CDTi (150bhp version they put in Vectra's).
Had this car 3 years now and never had any bother with it (only done 81k on a 56 plate, never modified), used it to go to London and back for years and alsorts. Anyways, few months ago all of a sudden it just stopped pulling, as most will know these engines are "pokey" at the very least so you know when they are boosting properly. Replaced the EGR then most recently the intake because it was coked to bits, but still not pulling properly It's not too awful to drive but it tends to go into limp mode which can be unbearable.
The intake was not cheap to do, even with the brother doing the labour, he says the turbo seems ok as in no leaks or play but possible the rest of the exhaust system and/or CAT could be coked up too? The error codes are the intake though which is confusing. Obviously nearing the point where you wonder what you are doing wasting time and money on a 12 year old car, but it is a nice car and does all I need.
Codes:
P2279 Intake Air System Leak
P0100 Mass or Volume Air Flow A Circuit
P0105 Manifold Absolute Pressure Circuit
The last 2 could be related to having unplugged the battery during the new intake install.
____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
andym |
andym World Chat Champion
Bikeless |
Bikeless World Chat Champion
AshWebster |
AshWebster Brolly Dolly
johnsmith222 |
johnsmith222 World Chat Champion
Tariq_S |
Tariq_S Two Stroke Sniffer
Irn-Bru |
Posted: 17:43 - 16 Jul 2018 Post subject: |
I've tried cleaning the boost sensor on the inlet, but not tbe maf. I haven't really tried a leak test yet (spray wd40 around the engine bay until revs rise?), would issues with the exhaust not bring up separate codes? The EGR is also brand new since they are so cheap, I previously had issues with it about 20000 miles ago, I just cleaned it and it was good as new but replaced it this time in case.
The EGR and swirl valves are now all blocked off whilst doing the intake Belt, water pump, pulleys ect were done when I first got the car. Just had the alternator done recently too, it was that bad I thought it was my gearbox but luckily not ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
Nb |
Nb World Chat Champion
stevo as b4 |
Posted: 21:30 - 16 Jul 2018 Post subject: |
Mafs do die, will cause a big loss of performance and or limp mode. Ive never liked Maf's even on petrol engines where there's really no need to use them over MAP and TPS sensors.
If the Maf is fucked and the engine is otherwise in good condition, I know for some derv cars in this pre Euro 4 era, you can get Mafless re-maps done too, which solves the problem of failing MAF sensors every few years.
Oh and if your EGR is blanked off and your car is pre DPF era, then as said get the catalyst sorted inside or a straight pipe fitted. Diesels were never meant to be clogged up with all this shit, and actually drive really well and how they should with all the crap removed
Anyone remember the first generation mechanical turbo diesels? They were very all or nothing, but on boost they went properly especially with the fueling turned up a bit. |
johnsmith222 |
Posted: 23:03 - 16 Jul 2018 Post subject: |
Irn-Bru wrote: | I've tried cleaning the boost sensor on the inlet, but not tbe maf. I haven't really tried a leak test yet (spray wd40 around the engine bay until revs rise?), would issues with the exhaust not bring up separate codes? The EGR is also brand new since they are so cheap, I previously had issues with it about 20000 miles ago, I just cleaned it and it was good as new but replaced it this time in case.
The EGR and swirl valves are now all blocked off whilst doing the intake Belt, water pump, pulleys ect were done when I first got the car. Just had the alternator done recently too, it was that bad I thought it was my gearbox but luckily not |
Those circuit codes that were mentioned previously are for the mass air flow sensor, and the map sensor (the "boost sensor"). I would be looking at both of those, cleaning the sensors again, checking and cleaning the connector blocks/contacts.
If you deleted the codes, check them again to see if any returned (e.g. its possible you or your brother might have caused one of them through unplugging a sensor, but the other may be a genuine ongoing problem with the circuit).
MAF sensors start from about £30 for my car, so should be similar or less for yours. Might be worth replacing if suspect. That said I'd probably try testing and cleaning the one on there first as i dont like just buying parts that may or may not solve it.
Do you know anyone with a vectra c or saab 9 3 1.9 tid that could let you try their MAF to see if that fixes it?
Another thing to check is the hose going directly onto the intake manifold. I've had mine slip off slightly itself. The clamp needs to be pretty tight.
The other thing to consider is there might be a split in that hose. It's not happened to mine, but happened to a friends 9 3, and another 2 9 5s in the same family (the 9 5 is a different engine, but similar hose design. |
The last post was made 5 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
