Gear Shifting Very Difficult
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3
flyingcbf
PostPosted: 21:50 - 25 Apr 2024    Post subject: Reply with quote
I've just done a bit more research on YouTube and two user's have suggested that the last friction plate does not go along with the other plates. It goes to the opposite slot.
I'm strugling to attach photos from Google photos so thanks to 'StinkWheel' for helping me out. I'm going to try again...
I have installed the clutch plates wrong...
https://lh3.googleusercontent.com/pw/AP1GczN9M887jFnMx9JWvsQ1xg3XzLS61lHqVjnSeJqCb3AsZxvcLpOTCRJEU3tThQni6mZHDG_PDVgFYRI9HIq2X1YpQ6i8Xa3awRW2l-WR5pOluVnmtVyZ8oo6ugcmgVER4k-J4OXPdlGndF9SNCJHX_4m=w1215-h911-s-no-gm-no
The correct way is this, so the last clutch plate is installed on the next slot, as in the picture below...
https://lh3.googleusercontent.com/pw/AP1GczOILagQ3Ot8f8ix-odMKIOx1-mOQQqTSpXLVZCCz5Zl1d-YkKJ8KMJwBbw18VWLb7Q7QlND_rm-02Jlk_ryGbtCT-1AS3m5OhEaOKLQK-h_r5Q7MGyeC7NPEJ89PWIgMgpll-54ijQXbZWrrcXKIepY=w942-h522-s-no-gm-no
Notice the last plate is installed in the opposite slot..
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
PostPosted: 21:58 - 25 Apr 2024    Post subject: Reply with quote
You are a bit incompetant at pictures. I'm not telling people which one this is.
https://lh3.googleusercontent.com/pw/AP1GczMRnIl6eYqpzy7BZLnlfZRctLiaPbXgJRwdT7cDCNEIPYs-1YAKYNQ2Yns61cMPA0aK-4bYhdO4R-2hhKO89J36EEy976qAXNP5FPTE-n45LPvV1xux2PqZOnM_DH54qWBy6C84EDCSHpVtu0zfe3kw=w1396-h1047-s-no?authuser=0
jeffyjeff
PostPosted: 21:59 - 25 Apr 2024    Post subject: Reply with quote
flyingcbf wrote:
....So any suggestion as to where to look? Clutch Friction Plates???
I would start by carefully examining the engine oil, which is shared with the transmission and clutch. Rub some oil between your thumb and forefinger...see if you can discern a loss of lubricity or the presence of debris (clutch plate material). Smell the oil. Can you detect the odor of fuel? Does it smell burnt? Fuel dilution and overheating will cause the engine oil to loose its ability to lubricate. Your problem could be related to a fuel system problem or a faulty oil cooler.
Absent any clues you might discern from the oil, clutch plates are a good place to look. I would mic out the plates individually and measure the stack and check against published specifications. Examine the clutch hub and basket for wear that might impede the clutch plates from free lateral movement. Look for evidence of two clutch plates that might not freely separate. You might consider lightly sanding the friction plates to remove any imperfections that could affect stack height, and to remove glaze that might gum up free plate movement. Upon reassembly, it might be a good idea to mix the plates up from their original locations. Standard practice is to soak the friction plates in oil prior to assembly.
flyingcbf
PostPosted: 09:04 - 26 Apr 2024    Post subject: Reply with quote
Engine oil has just been changed, twice. I did an oil flush.
I'm going to attempt to open her again today weather permitting and check the clutch plates. I'll check the oil too as suggested. Thumbs Up
flyingcbf
PostPosted: 12:37 - 26 Apr 2024    Post subject: Reply with quote
After watching some videos below,
https://www.youtube.com/watch?v=wblPnGEQgsg
https://www.youtube.com/watch?v=nbr7lL3balg
it seems that the clutch plates in this bike are already correct, so there must be some other underlying issue Sad
flyingcbf
PostPosted: 11:22 - 08 May 2024    Post subject: Reply with quote
OK, I think I've solved the issue!!!
The problem was with the clutch basket.
It's made of aluminium and over time gets scored with the clutch friction plates. Check the picture.... Notice the 'ridges'?
https://lh3.googleusercontent.com/pw/AP1GczMlrZoMhZVhZzZ1dr-n8obkZEJCuuAWpeOj7IyYOWkNG_5r-CVJlh0NfMbjBEKn4bONUGAtBlLOW1uNTP0DnYjtOq_agZfWEUH01nsR2qYBiSqPePUQ-OfypL_GMyHoXLWUqiRlU_UtL1c0PYYbwWw2=w844-h545-s-no-gm-no
I've had to sand these ridges down with coarse sand paper and then go over it again with a fine sand paper P600. Cleaned off with brake cleaner and then put oil back in.
It's running sweet now for hours on end!!! Very Happy Very Happy Very Happy
Although the other thing I did was also to clean the friction plates with brake cleaner.
I hope this info will help some one out!!! Thumbs Up
PostPosted: 12:40 - 08 May 2024    Post subject: Reply with quote
Congrats, glad you're sorted - see also post # 5 from Stinkwheel.
flyingcbf
PostPosted: 14:39 - 08 May 2024    Post subject: Reply with quote
Yes, stinkwheel really helped out! Thumbs Up
There is one downside to doing this though. I've noticed the sound is little louder and also the bike slighly more 'vibration' if I may say. As there is now less material for the friction plates.
pdg
PostPosted: 14:51 - 08 May 2024    Post subject: Reply with quote
You'll likely also find it'll wear quickly again (well, quicker than the first time) as the fingers on the plates now have more room to bang back and forth in the basket...
A new clutch basket would be the 'proper' fix of course, but that costs actual money and may or may not be obtainable.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
flyingcbf
PostPosted: 15:49 - 08 May 2024    Post subject: Reply with quote
Yes, your right! It will wear faster.
I've been looking at a steel clutch basket online but can't find one anywhere on the net. I think it needs to be machined made somewhere.
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.28 - MySQL Queries: 16 - Page Size: 74.19 Kb
