CBR600 Headlight Woe
Acemastr
PostPosted: 08:39 - 10 Jun 2010    Post subject: CBR600 Headlight Woe Reply with quote
Came to my bike this morning, sidelight works, low beam doesn't work, and nor does high, but my 'pass' switch does work...
any clues?
Bike is a '97 CBR600F3
2016 Toyota Tacoma Limited
SlimRick
PostPosted: 08:47 - 10 Jun 2010    Post subject: Reply with quote
Possible the switch - squirt a load of WD40 into it.
Raffles
PostPosted: 09:00 - 10 Jun 2010    Post subject: Reply with quote
If your bike sleeps outside then it is likely to be water ingress within the switch that is causing the problem, as suggested above. If the switch can be opened up then it may be an idea to clean the inside of it as soon as you get an opportunity to do so.
Acemastr
PostPosted: 09:02 - 10 Jun 2010    Post subject: Reply with quote
It does live outside under a cover, I'll give it a try as soon as i can, seems the bulb is fine, just doesn't switch to main beam, high/low button does nothing too (obviously)
Raffles
PostPosted: 09:16 - 10 Jun 2010    Post subject: Reply with quote
Covers only provide scant protection. If the bike is wet when it is covered up then you are trapping the moisture inside the cover and sometimes that can be worse than leaving it exposed to the elements. If you can obtain a breathable type of cover then the extra cost of purchasing same will be money well spent as the bike will be ventillated as well as being protected from the rain etc.
That_Hornet
PostPosted: 09:21 - 10 Jun 2010    Post subject: Reply with quote
Contact cleaner Thumbs Up
Acemastr
PostPosted: 19:42 - 10 Jun 2010    Post subject: Reply with quote
fixed it! little red connector behind the dash had come apart.... it took me 90minutes to get the clocks out... the screen out... the mirrors off... my god what a stupid place to put it.
Noxious89123
PostPosted: 20:58 - 10 Jun 2010    Post subject: Reply with quote
90 minutes?! You need more practice! I can strip all the fairings off my bike in less than 30.
Glad to hear you sorte it though Smile
Acemastr
PostPosted: 22:02 - 10 Jun 2010    Post subject: Reply with quote
I tried to do it without taking all the front fairing off, needless to say it didn't go well :p
The last post was made 13 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.1 - MySQL Queries: 17 - Page Size: 60.62 Kb
