Speedo drive- easy job?
DaveS
PostPosted: 01:58 - 08 Apr 2004    Post subject: Speedo drive- easy job? Reply with quote
The speedo on my F-Reg Yamaha TZR-125 isn't working.
I have changed the cable which was in a bit of a state, and I know the gauge is working because its only showing 25 miles and looks brand new (its an aftermarket one not the standard TZR clocks).
This leads me to the conclusion that it must be the thing that turns the cable at the wheel. How easy is this to replace? Could I do it myself and will it be expensive?
Is there anything else I haven't thought of?
Thanks in advance,
..DaveS
mr.z
PostPosted: 03:19 - 08 Apr 2004    Post subject: Reply with quote
Its a front wheel off job, not difficult though, if you have a torque wrench and something stable to prop the bike up onto (i used a car jack to lift it and a load of wood to keep it there after takeing the jack away, but there is probably a better way) haynes manual or similar is also something you need if your going to do anything major like pulling wheels off not least for torque settings..
If its the same as mine its a drive thats between the fork and the wheel you pull it out and thats it, might just need greasing...
(do this before pulling wheels off) Take the drive out at the clocks end and see if it turns with the front wheel, if it does then you can rule out the drive and the speedo cable, then maybe try takeing it out of the drive end after and using a drill on very low speed (carefully though would be easy to brake it) if the speedo don't go then its the clocks (probably).
Hope that helps, make sure to use loads of grease so you don't have more problems later on...
Hope that gives you somewhere to start looking Wink
The last post was made 20 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 32.46 Kb
