And we thought Gixxerkart was crazy.
bikedudextrm
PostPosted: 00:53 - 21 May 2004    Post subject: And we thought Gixxerkart was crazy. Reply with quote
This kart has a jet turbine engine Shocked . It's got to be a GixxerKart killer.
Who ever thought of putting a jet turbine engine in a Kart Sick .
https://www.meditech.ch/exoticthermoengineering/films/kart%20turbine%20high.wmv
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
Mr C
PostPosted: 00:59 - 21 May 2004    Post subject: Reply with quote
it looks like the turbine is actually driving the wheels or why did it wheelie
sounded like it blew up at the end as well Twisted Evil
187.3bhp = 201mph
PostPosted: 09:40 - 21 May 2004    Post subject: Reply with quote
Its a jet turbine, it must be driving the wheels. If it wasn't they'd just call it a jet! Laughing
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Mr C
PostPosted: 10:15 - 21 May 2004    Post subject: Reply with quote
err no actually
a jet is a turbine only it uses the hot gases produced accelerated through a nozzle to produce a reaction like a rocket
the turbine itself is just the bit that imparts a rotary motion to a shaft to drive the compressor (only in a jet) or another piece of equipment - wheels in this case
the whole thing is called a gas turbine whatever
trust me - I have been working with them for the best part of 20 years
the trouble with small gas turbines is that (like turbochargers) in order to get the compressor to work efficiently they have to spin at a ludicrous speed - at that size it's probably over 100,000 rpm (no typo) - that being the case it is difficult, read impossible to reliably gear it down and still produce enough torque to actually get anything off the line. Also they only tend to operate at two speeds, fast and amazingly fast so you can't really modulate speed with a conventional throttle like a reciprocating engine and have to have another way of controlling the amount of torque/power transferred to the wheels
it was difficult to see but that one looked like it was installed backwards and the rotating piece you could see was actually the compressor inlet - although it could equally be the turbine outlet, hard to tell
generally anyway if it was and you can see the turbine outlet like that then there is no nozzle, no acceleration of hot gas and no jet effect
judging by the clouds of white smoke, it also wasn't burning very well, at a guess runnning on diesel
it looked like a converted turbocharger
neat idea all the same Cool Cool
187.3bhp = 201mph
bikedudextrm
PostPosted: 14:13 - 21 May 2004    Post subject: Reply with quote
Yes Mr C it is a gas turbine a hydrogen peroxide turbine to be precise Razz . In the second run it was the actual tires that blew Shocked and the wheels are spinning at 7K RPM which is insane.
Police Tut Tut
Mr C
PostPosted: 18:04 - 21 May 2004    Post subject: Reply with quote
sounds wrong to me
Hydrogen peroxide is rocket fuel, you can't run a turbine on it
it doesn't need oxygen to burn as it carries its own and burns way too hot for a metal turbine to survive in it
more likely diesel
187.3bhp = 201mph
kev
I Hump Things
PostPosted: 09:24 - 22 May 2004    Post subject: Reply with quote
Its a gas turbine running on kerosine diesel mix, I saw one like it at santa pod about a year ago.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Mr C
PostPosted: 11:23 - 22 May 2004    Post subject: Reply with quote
thanks kev that makes more sense
Kerosene is what all aircraft jet engines run on - paraffin
We run ground based turbines on diesel as a secondary fuel, natural gas as primary fuel - usually
187.3bhp = 201mph
The last post was made 20 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 14 - Page Size: 56.63 Kb
