Author |
ThunderGuts |
Back to top |
stinkwheel |
Posted: 16:24 - 20 Nov 2019 Post subject: |
You using a single speed chain? Not sticking a flimsy 10-speed on there? What brand you using? I presume you're on 1/8"?
I'm a fan of KMC Z1 chains. It'll cope with my 17 stone stomping on it on my SS 29"er MTB and that is geared 23-21 with 175mm cranks. Keep going uphill until it simply wont go any further. That's a lot of force. I had to buy a white industries freewheel because I was killing a shimano one every 3rd outing.
I see no reason you couldn't fit an automatic chain oiler like a loobman? You know how well they work for motorbikes.
Or there is the fully -old-school putoline chain wax. Clean the worst of the yad off the chain, stick it in the tin of solid graphited grease and stick it on top of the stove to melt. Deep cleans and lubes. Very effective. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThunderGuts |
Back to top |
stinkwheel |
Posted: 12:01 - 21 Nov 2019 Post subject: |
The rear cogs can hook badly too, more a concavity on the drive face of the tooth where the roller touches. The one on Mrs stinkwheels fixie was horribly hooked when we compared it to a new one (looked fine on the bike). You can flip miche-type track cogs on the holder to use the unhooked side... but you're single speed, not fixed right?
A mate of mine who does moon-mileage on his Rohloff hub-ed abortion of a bicycle (be a funny world if we all liked the same things, but it's effectively single-speed in terms of chainline) swears by the putoline chain wax. Used to be called linklife. He says the thickness of the grease prevents dirt getting into the links in the first place. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThunderGuts |
Back to top |
stinkwheel |
Posted: 16:40 - 21 Nov 2019 Post subject: |
While stripping and servicing freehubs is in theory doable, it is no errand for the impatient, numb-fingered or poorly sighted.
charliethebikemonger does a lot of ss specific stuff.
I always thought hub gears were pretty robust. Sturmey Archer also do a fixed-gear 3-speed.
If you want to be super oddball, how about a 2-speed kick-shift hub? Marketed as "duomatic". That's what's going on my pub bike when the shonky rim I have on it finally eats itself.
Geared 1:1 and 1:1.38
If you are going 3-speed, I'd suggest you get one with the rotary gear selector rather than the conventional 3-speed chain.
I built my brother a bike with an 8-speed hub that covers a higher range of gearing than most 20-speed bikes.
Remember shimano also make hub gears.
EDIT. Pics attached of sturmey archer 8-speed hub.
https://www.bikechatforums.com/download.php?id=102931
https://www.bikechatforums.com/download.php?id=102930 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThunderGuts |
Back to top |
The last post was made 4 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
