CorriganJ |
CorriganJ Scooby Slapper
Posted: 16:25 - 05 May 2020 Post subject: |
Soft panniers usually have two adjustable straps that sit on top of the saddle and the panniers hang down either side.
Some have an additional strap you put under the saddle to stop them sliding off to one side or the other. Some have straps on the pannier itself you attach to a frame rail/footpeg hanger for the same reason.
So likes of the oxford sports ones, you pop the saddle up, put a velcro strap across under the saddle then put the saddle down and put the two main velcro straps over the saddle. With my ortleib ones, you join them together with two velcro straps then drop them down over the top of the saddle. Then there are two adjustable straps at the front that clip to the pillion peg hangers and a third one that goes round the back of the tailpiece.
You can fit pannier rails for them to rest against so they don't rub the paintwork on the tailpiece, Many rear racks will have pannier rails incorporated in them. Or you can put some sort of protective matting over first, or use helicopter tape to protect the paint. Or don't bother and put up with rubbed paint.
The important bit is you attach them in such a way as they can't touch the exhaust or get pulled into the back wheel.
Lomo watersports (makers of canoe dry-bags and wetsuits) are doing some remarkably cheap, waterproof throwover motorcycle panniers. £50 a set last time I looked. Waterproof enough to throw in a river and expect the contents to staty dry. Also no zips, which is what always breaks on soft luggage and is never included in the warranty. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
doggone |
doggone World Chat Champion
CorriganJ |
Posted: 17:08 - 05 May 2020 Post subject: |
If I personally was going to use throwovers for touring on a GT125. I'd get a set of those lomo waterproof ones and I'd stick a wide strip of clear helicopter tape/rhino tape along the plastics for them to rest on.
Probably wont be able to fit a "universal" rack without some metal bracket fabricating. As doggone says, you used to get them for twinshock bikes which attach to the top shock mounts but monoshock bikes are too varied in their setup to make this workable.
A company called shad seem to make a rear rack with integral pannier rails for your bike.
Again as above, lomo drybags are great. Strap them to the pillion seat with bungees/rokstraps. Some of them convert to backpacks. They are good, tough and cheap. The side-entry ones are easier to live with because it's easier to get stuff out from the bottom of the bag. If you order stuff from there, get some of their bungees too, they are properly strong ones. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
CorriganJ |
The last post was made 4 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
