SR500 Ignition Question
ChrisA1983
PostPosted: 21:07 - 17 Oct 2023    Post subject: SR500 Ignition Question Reply with quote
Hi all,
New to the forum and new to bike building. Picked up a half done kick start SR500 chopper conversion recently and have an ignition question.
Just installing a fuse box and it comes with 3 wires; positive, negative and positive ignition. My question is, when putting a tester on my current ignition, it's showing as 2 negatives (1 in the on and 1 in off position). Obviously on connecting the ignition wire to this (before checking!), it blew the fuse. Is 2 negatives correct? And if so, where would I connect the ignition positive? Obviously if I touch it to the positive on the battery everything works fine.
So hard to find anywhere where you can ask a quick question so hopefully someone here can point me in the right direction
Thanks in advance.
PostPosted: 21:10 - 17 Oct 2023    Post subject: Reply with quote
I would imagine (if it doesn't earth through its body) oneof the positives is for the lighting etc. and one is for the sparks with a common earth.
jeffyjeff
PostPosted: 20:49 - 18 Oct 2023    Post subject: Re: SR500 Ignition Question Reply with quote
ChrisA1983 wrote:
...My question is, when putting a tester on my current ignition, it's showing as 2 negatives (1 in the on and 1 in off position).
Unaware of any need or purpose for a switched negative on a negative ground electrical system. Are you sure that you did not mistakenly invert the meter leads when you took your measurement?
PostPosted: 21:53 - 18 Oct 2023    Post subject: Reply with quote
None of this makes any sense to me.
why would a fuse box have a ground wire?
what function would that serve?
a fuse box isbasically, a pass through device
Power in and distributed power out, thassit.
No grounds needed.
The whole description is highly suspect (bollox) to me
jeffyjeff
PostPosted: 00:37 - 19 Oct 2023    Post subject: Reply with quote
...half baked kick start SR500 chopper pretty much sums up all you need to know.
PostPosted: 08:56 - 20 Oct 2023    Post subject: Reply with quote
Surely the fuse should be between the battery and the rest of the wiring, as near to the battery as you can get it.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 47.4 Kb
