Suzuki GSR750 (2011) steering damper
GSR750guy
PostPosted: 10:41 - 18 Feb 2024    Post subject: Suzuki GSR750 (2011) steering damper Reply with quote
Considering fitting a steering damper to the bike. Bought it last summer and felt the front end was a bit too easy to wobble.
Anyone got experience of doing similar and could offer advice? Sources etc? Do aftermarket ones fit pretty well? Not a lot out there for my bike and most I see (the more wallet friendly ones) seem to be designed to sit on top of the bars rather than tucked away under the instrument cluster for example.
Would prefer to have it mounted a bit more hidden than sitting on top.
2011 GSR750
PostPosted: 11:10 - 18 Feb 2024    Post subject: Reply with quote
Wobble and Weave.
Murray Walkers video. (Circa 1887)
https://youtu.be/fvsDIq3WwVA?si=lVyctBb0ybHzQT-K
I think they need to be calibrated for the bike.
Obviously mounted in a position that doesn't limit steering. (Except as intended.) Frame geometry and cetera comes into it.
My bikes came fitted from OEM. The bike that never had them never needed them. I'm an ace rider you see.
One has to understand the physics that cause unstable steering. Dampers work. Just fit properly like you asked.
Edited to include the stupid link. Embarassed
jeffyjeff
PostPosted: 18:31 - 18 Feb 2024    Post subject: Reply with quote
MCN wrote:
...One has to understand the physics that cause unstable steering. Dampers work. Just fit properly like you asked.
To MCN's point, the steering head bearing, fork tube alignment, and tyre wear can all contribute to a motorcycle's propensity to wobble at speed. On assembling the front end, tightening fasteners in sequence could play into it, i.e. tightening the front axle pinch bolts before tightening the axle nut. Check your workshop manual.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 16 - Page Size: 37.4 Kb
