1998 cb600f3 clutch
Bike Chat Forums Index -> The Workshop via View Category
Microwaveable
PostPosted: 11:43 - 03 Sep 2023    Post subject: 1998 cb600f3 clutch Reply with quote
Hi all. We are trying to find all the parts for a clutch rebuild. I see from our local Honda shop, some parts are not available even from Japan. Any idea where we might find these. Thanks in advance. Please see below
Details below, prices retail inc gst (x Japan is approx. 3 weeks)
#6 22125-ML7-000 (Seat, Judder spring, x1) $24.59 x japan
#7 22201-MAL-600 (Disk, clutch friction , x8) $38.96 ea x auck
#8 22202-MAE-000 (Disk B, clutch friction, x1) $38.96 x auck
#9 22321-ML7-000 (Plate clutch, x8) $23.38ea 3x auck 5 x japan
#11 22361-MAL-600 (Plate clutch lifter, x1) No longer available
#13 22401-MV9-670 (Spring, clutch, x4) $16.58 ea x japan
#14 22402-ML7-000 (Spring, judder, x1) $50.85 x japan
#17 90241-KM9-000 (Nut, lock, 20mm, x1) $27.70 x japan
#18 90432-121-000 (Washer, lock, x1) $14.83 x japan
#19 90457-MV9-670 (Washer, 22mm, x1) no longer available
#20 90554-700-000 (Washer, trust, 20mm, x1) $9.68 x japan
#21 91001-KA4-003 (Bearing, radial ball, 12x, x1) $35.45 x auck
#22 91026-MV9-671 (Bearing, needle, 35x42x23, x1) $108.16 x Japan
PostPosted: 14:01 - 03 Sep 2023    Post subject: Reply with quote
Try David silver spares. They even do factory clutch service kits for some models.
Kawasaki Jimbo
PostPosted: 18:08 - 03 Sep 2023    Post subject: Reply with quote
Wemoto?
https://www.wemoto.com/bikes/honda/cb_600_fw_hornet_(pc34)/98
There is a gap of 194 days between these two posts...
Microwaveable
PostPosted: 05:40 - 16 Mar 2024    Post subject: clutch is in Reply with quote
Hi all, after quite a while and waiting on parts and free time to work on her we have it back together.
Today we are testing to see if the new clutch engages, and it does and seems to shift up the gears.
There is no oil in her yet, is that why it still feels like the clutch is partially engaged when I try to turn the rear wheel with the clutch lever pulled in?
The rear tyre is not free wheeling when the clutch is pulled in and the bike is in gear, just to get clear, but there is no oil in it and its not running.
thanks guys
PostPosted: 09:24 - 16 Mar 2024    Post subject: Reply with quote
I'd imagine it will be somewhat grabby with no oil in. May also need some adjusting.
You should be able to see the clutch stack seperating when you pull the lever if you look in through the oil filler hole with a torch.
Microwaveable
PostPosted: 22:38 - 16 Mar 2024    Post subject: Reply with quote
thank you
Fullers1845
PostPosted: 16:19 - 18 Mar 2024    Post subject: Reply with quote
He even has a museum with 200 Hondas on display, I'm staying nearby in the summer, might have to have a mooch around.
Honda CB125F, Kawasaki ZX6R J1, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 14 - Page Size: 51.74 Kb
