flimsy forks..
PostPosted: 10:24 - 01 Apr 2024    Post subject: flimsy forks.. Reply with quote
Having completed (mostly) the transplant of teh GP100 (disk brake - woo!) front end to the A100 Im shocked by the flex in the forks..
..only the bottom yoke has pinch bolts and I have not yet got a mudguard fitted. I'm assuming that the degree of 'twist' is normal and will be fixed by bracing with a mudguard - otherwise it would be unrideable I reckon.
PostPosted: 15:42 - 01 Apr 2024    Post subject: Reply with quote
Those steel mudguards or the steel inserts in plastic ones do a lot of bracing.
I presume the top yoke is a taper fit so it won't cinch down until the top-caps are tightened down fully
PostPosted: 16:44 - 01 Apr 2024    Post subject: Reply with quote
My experience of GP100/GP125's is that the forks are quite solid, it's the swingarm bearing being made of cheese thats the comedy part. It's like your riding a seesaw when you hit a bump half way round a corner.
PostPosted: 18:28 - 01 Apr 2024    Post subject: Reply with quote
Good point.. maybe i did teh lower yoke up first before teh top was 'snug'. I'll go and check..
PostPosted: 18:31 - 01 Apr 2024    Post subject: Reply with quote
Ha, the A100 seems quite solid at the back.. Still like moped but in the main beefier I think.
PostPosted: 11:21 - 02 Apr 2024    Post subject: Reply with quote
My installaton has left out the original headlight brackets and associated rubber grommets/seals..that cushion teh bracket form the yokes.
Hard to see how these could help avoid teh twisting though..
... I may fabricate soem kind of brace and order a mudguard.
PostPosted: 11:12 - 04 Apr 2024    Post subject: Reply with quote
A100man wrote:
My installaton has left out the original headlight brackets and associated rubber grommets/seals..that cushion the bracket from the yokes.
Hard to see how these could help avoid the twisting though..
This is the issue - seems these are needed to clamp the top yoke securely.. Sad
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.3 - MySQL Queries: 16 - Page Size: 53.7 Kb
