M1ke |
M1ke Ped Boi
knockout_bar |
knockout_bar Scooby Slapper
Posted: 19:58 - 09 Oct 2005 Post subject: |
The same order that they fell out in (that's if you can remember). If not, sorry I can't help ya mate. ____________________ 125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) |
Korn |
Korn Admin
Posted: 21:02 - 09 Oct 2005 Post subject: |
The ball should go in first, then the washer + spring and finally the bolt. The basic idea is they should hold the ball bearing in the drail hole opening when the whole lot is tightened. ____________________ 3516 Miles, 11 Countries |
M1ke |
M1ke Ped Boi
Shaun |
Shaun Likes 'em bent
Posted: 23:25 - 09 Oct 2005 Post subject: |
Korn |
Korn Admin
Posted: 00:32 - 10 Oct 2005 Post subject: |
It should drain ok like that. Also I don't know if your bike holds the oil in the frame but if it does there's usually another drain plug for that... ____________________ 3516 Miles, 11 Countries |
WildGoose |
WildGoose White Van Man
Posted: 13:14 - 10 Oct 2005 Post subject: |
ever felt out of your depth mike?
i told thee! ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
Valver |
Valver World Chat Champion
M1ke |
M1ke Ped Boi
Posted: 18:58 - 11 Oct 2005 Post subject: |
After a few people advised me ball bearing then spring I went with that and it ended up locking the gears! I could only select gear 2 and 3. So i undid the plug again and found the spring was rather mangled... oops.
Gave husky a ring and they informed me that it should have been spring then ball bearing and it is some sort of neutral selector (spring pops up into a hole to hold the gears in neutral) So I need a new spring |
Section59 |
Section59 Spanner Monkey
Posted: 21:59 - 11 Oct 2005 Post subject: |
LOL! /me will no longer accept any bike advice from korn.
He did it on purpose, any money. |
Korn |
Korn Admin
Posted: 00:03 - 12 Oct 2005 Post subject: |
I don't understand what you did. I've drawn a little diagram of how the pressure plug I was talking about should look (see attached), but even if you put it back together in the wrong order none of its parts can interfere with the gearbox - it's self contained inside its housing!
It sounds like you were working on something else entirely! ____________________ 3516 Miles, 11 Countries |
The last post was made 18 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
