mr jamez |
mr jamez World Chat Champion
Posted: 17:38 - 18 Mar 2004 Post subject: Engine rebuild |
I have basically stripped the whole of the NSR down now, and I thought it may be a worthwhile job to rebuild the engine, as I don't know the history of it and the previous owner didn't do any work on it. First of all what causes a 2 stroke to seize? is it just the piston rings? or the piston as well?. I guess that it will all need cleaning out, not to sure what to use really. Oh and what parts am I going to need, I guess new piston rings, head gasket and mabey a piston?
Can anyone think of some problems that I *may* encounter also
Or is this just a total waste of time and money
ta |
Robby |
Robby Dirty Old Man
mr jamez |
Posted: 19:53 - 18 Mar 2004 Post subject: |
Right ok thanks, the engine is ready to come out now so I will do that tomorow. Think I will just replace the whole lot, don't really want to be doing this again. If I get stuck I will just have to drag one of you down here or something |
Kickstart |
Kickstart The Oracle
Posted: 19:59 - 18 Mar 2004 Post subject: |
Once you have enough off the NSR to take off the top end of the engine it is quite easy to remove the engine (far easier than the RS125 or the Mito).
Siezures are normally caused from lack of oil. However running lean can do the same (causes the bike to overheat), as can running hot for any other reason (no coolant, blown head gasket, knackered water pump, etc).
If it has seized then the piston will almost certainly be knackered.
mr jamez |
Posted: 21:39 - 19 Mar 2004 Post subject: |
Well I dragged it out today, had a bit of a mishap with the gear box oil staining my legs but otherwise it went fine
Just to clarify, I will need:
Cylinder head gasket
Cylinder base gasket
Piston
Piston rings
gudgeon pin
Small end bearing
left + right crank case gaskets
Also I had a few problems with the clutch, but whether that was with it not being used that much I dunno. Are they hard to fit, do you need any special tools etc? the front sprocket also looks a bit funny, some teeth look *sharper* than others?
ta |
Kickstart |
Posted: 23:19 - 19 Mar 2004 Post subject: |
You will also need some circlips (sometimes known as "oh shit" clips, as that is what you say when they ping across the garage).
I am not sure with the NSR, but clutches can sometimes be a pain to fit, depending on how they are located (eg, FZ750 it is a doddle to change the clutch, but G had quite fun fitting one to a Hornet at the drag strip).
mr jamez |
Posted: 18:58 - 21 Mar 2004 Post subject: |
Right nearly there now, although there seems to be a small mark/crack in the plating on the cylinder wall It is very small, the engine seemed to run ok with it like that. |
jimbo |
jimbo Borekit Bruiser
mr jamez |
Posted: 20:58 - 27 Mar 2004 Post subject: |
Well I have already decided to get a new barrel and I think your post has made me certain, about £90 with a piston so not that bad really. I can feel it with my nail and I don't want all the parts I am putting in now to get broken because I didn't spend a little bit more.
Better safe than sorry
How much is it to get it replated? |
cagiva gezzer |
cagiva gezzer World Chat Champion
Posted: 14:44 - 28 Mar 2004 Post subject: |
www.stanstephens.com
Not saying go there, but the prices that he charges are about normal. ____________________ "because one stroke isnt enough and four strokes waste two" |
Git |
Git Brolly Dolly
Kickstart |
The last post was made 20 years, 68 days ago. Instead of replying here, would creating a new thread be more useful? |
