dr_chriz |
dr_chriz Two Stroke Sniffer
MarJay |
MarJay But it's British!
Posted: 11:21 - 22 Mar 2004 Post subject: |
Hi dr_chriz! Welcome to the forum.
The FI international restrictors are always just small washers in the intake manifold (unless its a REALLY powerful bike like a TL1000 or something where they put a throttle stop in too). You need to remove the carbs and lever them out of the carb rubbers which will be left on the intake manifold. Unless you completely dismantle the carb rubber assembly and remove them, you WILL damage them. They are not needed for an MOT and they won't check for them. The only thing is if the police ask to inspect your bike, and thats when they would need to go back in, but the chances are the police would have the bike away too quickly for you to do anything about it.
IF you do go ahead and derestrict it, then the carbs will need to be balanced and the bike could probably do with a service at the same time to get the best out of the new unrestricted performance.
Remember, if you decide to do it, it is your own decision and you have to know that you will be riding without a license and technically uninsured. If you have ANY doubts about it I would say leave them in and wait for your two years to be up.
Good luck! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
dr_chriz |
Robby |
Robby Dirty Old Man
MarJay |
Posted: 12:12 - 22 Mar 2004 Post subject: |
Robby,
When I had my VFR restricted all of the washers were different tolerances and so were balanced differently with the washers in than with them out. They evidently needed balancing when they were put in, so it stands to reason that they needed balancing after they 'fell' out.
I only speak from experience. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Ste |
Ste Not Work Safe
Posted: 12:49 - 22 Mar 2004 Post subject: |
I wouldn't expect a bike shop to adjust your carbs for them, as all four washers are the same, and all four carbs should be set the same to start with. I specifically told the shop not to change any settings on anything when they put mine in.
Ahem, Mark, I know nothing about things like throttle stops on TL's. |
MarJay |
Posted: 13:05 - 22 Mar 2004 Post subject: |
The bike shop that restricted my bike did balance the carbs and therefore they needed balancing again when the restrictors 'fell' out. Capisce? ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
dr_chriz |
MarJay |
McJamweasel |
McJamweasel BCF Junkie
Kickstart |
Kickstart The Oracle
The last post was made 20 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
