Bhud |
Bhud World Chat Champion
Posted: 01:29 - 19 Jul 2022 Post subject: Bottom bracket axle/crank failure |
90-ish year old broken axle.
They call this a bottom bracket axle, I think. Don't know why - I'd call it a crank, but whatever. This piece connects the pedals on my (only) pedal bike. It's very old, and I felt like sharing this here because (a) cycling forums, universally, suck, and (b) I'm amazed this has happened.
English road bike from the 1930s. My legs have got so much stronger over the past month or so. Anyway, the bike has flat bars, but is otherwise standard, and I've been absolutely hammering it on a BMX track and gravel paths every other evening. So, what happened was, my legs got stronger than this axle could handle, and it's only got 3 gears, and so when I went up a very steep little hill my legs could handle it but this part couldn't. It sheared internally with torsional force. Fortunately, was able to source another part (it's a precise part made by Bayliss) which is on its way to me.
I'm just sharing this for mechanical interest as well as historic. A Google search suggests that this happens between 25000 and 50000 miles, which is absolutely staggering mileage. Not sure if I believe that, but it's definitely metal fatigue anyway. If you put the two parts together, they don't join together perfectly, because they twisted before they broke. Think it's called "plasticity" or something. But I feel strong putting out torsional Nm like that!
https://i.ibb.co/hB57Pqh/broken-axle.jpg |
Posted: 18:29 - 19 Jul 2022 Post subject: |
It's snapped through the cotter pin area so probably not a torsional fracture because that part should be fully supported within the crank. It's probably reveiving a fair bit of shear force or even flex there. I bet the cotter pin doesn't make particularly good surface contact across the entire cutaway.
If you want to prevent that happening, I'd suggest you "bed" the cotter pin by applying blue to the flat, fitting, removing and filing/grinding/sanding down the high spots until it makes maximum surface area contact. A bit like they do with the wedges on power hammer swage blocks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Bhud |
Posted: 22:17 - 19 Jul 2022 Post subject: |
In fairness, you can even see on your photo the limited amount of contact the cotter was making on that spindle. Looks like there was only about 2mm front and back leaving the entire centre unsupported. Compare that to the amount of contact you get on even a (now comparatively obsolete) square taper.
EDIT: The cotter pin was probably slightly bent then refitted. In fairness, I don't think I ever saw many straight ones. I think it used to be pretty common to try a few in until you got a "good" one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Bhud |
Bhud |
ThunderGuts |
Posted: 13:39 - 20 Jul 2022 Post subject: |
Not quite as simple as the above because while you will almost certainly be able to get a sealed bottom bracket with the correct threading quite easily, it will be a taper type and the original cranks for this bike are cotter pin fitting. So it would need different cranks fitting too.. Unless someone is making a sealed BB with cotter pin fittings.
When I said BSA threading, the majority of bicycles with a threaded bottom bracket use BSA thread sizes... Except for the ones that don't (see Sheldon Brown above). You could walk into halfords today and buy a bike with a BSA threaded bottom bracket.
EDIT: Well spank my arse and call me Charlie. If your bottom bracket axle is 136mm wide, you're onto a winner.
https://www.sjscycles.co.uk/bottom-brackets/cottered-sealed-bottom-bracket-136-mm/ ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ThunderGuts |
The last post was made 1 year, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
