mod 1 passed, mod 2 failed - Update mod 2 PASSED!
snomag
PostPosted: 16:27 - 17 Jun 2009    Post subject: mod 1 passed, mod 2 failed - Update mod 2 PASSED! Reply with quote
Earlier today I had my module 1 and module 2 test and as the title suggests, I kinda failed the second part. Still I thought I'd do a bit of a writeup, maybe it helps someone:
I was really stressed about doing the first part of the new test, but it's not that hard at all. (ofc I've to say it as I passed it..) A few tips that helped me getting it done nicely:
Manual handling: When I was asked to wheel the bike backwards, I found it a LOT easier, with me being on the inside of the turn. You can also change the way you hold on to the bike anytime - as long as you don't loose balance - without any problems.
You don't have to put the bike on the centre stand, it's enough if you use the side stand.
Slalom/ Figure of eight: The slalom should be fairly simple for most people as the gap between the cones is big enough. Just try not to focus on the cones, and it should be fine.
The figure of eight was something I was really afraid of (and I mean REALLY) but than I realized I don't have to prove how good I am and I don't have to do it that tight. On the test, you can use as much space as you want, so make it as wide as you want, which should make it quite easy.
Hazard avoidance: I don't think if it's that bad to be honest. If you make sure you're up to speed, the swerving itself is next to nothing. Once you hit the speed trap, just make sure you roll off the throttle (on a big bike, stay in 2nd gear, the engine braking helps a lot), swerve away THEN brake! Don't brake before getting back up to a straight line, there's no need for it (there's more than enough room to stop, even in wet) and it just makes it dangerous.
U-Turn: This became really easy with the new test, just make sure you do your lifesaver before you commit yourself to the turn and that's it.
Slow control: Nothing really to say about this one, just stay behind / next to the guy and it's done. Keep the revs up, control the speed with the clutch and cover the back brake in case you need to slow down a bit.
Emergency stop: Speed up, brake, don't lock it or fall off Very Happy.
Also, during the whole test, do check before you move off. Even when it's just the manual handling, look around, before you start wheeling the bike.
The whole thing takes like 10-15minutes, so it's not too bad I think. Doing all this in a huge, spacious car park makes it a lot easier too as you don't have to worry about cars, pedestrians, kerbs, etc..
So that's it for mod 1, in case you're interested, I failed my module 2 because I pulled out at a roundabout in a way that wasn't acceptable.
Basically I was coming up to a 2 lane roundabout, taking the exit to the left, with a car on the inside, indicating right. I looked at the driver, at the car's front wheel and saw that it wasn't going to pull outside, so I went for it, when the car's front wheel was just about in one line with me -> fail, I should have waited one more second untill it completely passes me.
It happened one minute before we got back to the test centre and I didn't cross the car's path or made him slow down, but as I 'trusted the indicator' I failed.
That_Hornet
PostPosted: 20:18 - 17 Jun 2009    Post subject: Reply with quote
Unlucky mate. Goodluck next time Thumbs Up
Adrian
PostPosted: 18:57 - 18 Jun 2009    Post subject: Reply with quote
Unlucky...book the next one straight away Smile
snomag
PostPosted: 22:48 - 18 Jun 2009    Post subject: Reply with quote
Yeah, I've done that, straight after the test
ryhardcastle
PostPosted: 16:21 - 22 Jun 2009    Post subject: Reply with quote
Unlucky pal. Glad to see you're putting straight back in for it. As you passed Mod 1 pretty comfortably it's clear you're a competent rider. I think it's just the nerves that make people make mistakes. Learn from this mistake and make sure you don't do it next time! Very Happy
I passed my module 1 yesterday and got my mod 2 in July. I'm actually really looking forward to it. I just need to get my observations and use of indicator sorted out. (I constantly forget to cancel my indicators! Mad )
Mr Hammers
PostPosted: 17:00 - 22 Jun 2009    Post subject: Reply with quote
Unlucky snomag, better luck next time, mate Thumbs Up
A Guide To Powerbands
Hazylogic
PostPosted: 14:57 - 25 Jun 2009    Post subject: Reply with quote
shit happens and that was just shitluck. hold fast and stay lucky Karma
supZ
PostPosted: 16:07 - 25 Jun 2009    Post subject: Reply with quote
a tip my instructor told me was to press it whenever you change gear (whilst getting used to it anyway)
if you think about it, whats one of the first things you do after taking a junction or pulling out? accelerate and change gear.. if you think 'change gear, press indicator' you'll soon get used to cancelling your indicator all the time Smile
even if you're pressing it when you dont need to at least you'll never forget to cancel it on the test Very Happy
my worst was if anything distracted me straight after the corner id forgot.. cars in the way, pedestrians wandering in the road, some hot blonde on the pavement and the like Wink
CBR954RR - Daily toy
CBR600RR - Trackbike
armedpitbull
PostPosted: 13:55 - 28 Jun 2009    Post subject: Reply with quote
i failed my mod 2 the other day. ive been told ive got to wait atleast 10 working days before i can take it again. is there anyway of gettin in sooner?
how can i write my signature when my pen wont write on the screen??
Adrian
PostPosted: 22:50 - 28 Jun 2009    Post subject: Reply with quote
Crap Sad I don't think there is, you are required by law a minimum of ten days. To be honest you're quite lucky if u can rebook after ten days, i had to wait 3 weeks for the second attempt and 20 days for third so i wouldn't complain about ten days. Good job you're re-booking it. You have not failed Smile u just didn't get it this time. Good luck next time Thumbs Up
Skudd
PostPosted: 12:34 - 29 Jun 2009    Post subject: Reply with quote
No.
Flip
PostPosted: 14:39 - 29 Jun 2009    Post subject: Reply with quote
If you fail one of the mods you don't have to resit both? They're completely separate like a theory test for example?
Been a while since I passed my test so I have no idea. Smile
ThoughtContro...
PostPosted: 16:46 - 29 Jun 2009    Post subject: Reply with quote
You get a certificate after passing mod1. You don't have to redo mod1 if you fail mod2.
Flip
PostPosted: 17:55 - 29 Jun 2009    Post subject: Reply with quote
In that case the op has done the hard part. Smile
tutton
PostPosted: 19:09 - 29 Jun 2009    Post subject: Reply with quote
Depends which bit you find better,
i find manovures peice of piss, keeping up lifesavers indicaton mirrors road positioning, and all that for 40ish minutes under close examination i find harder Laughing
supZ
PostPosted: 10:17 - 30 Jun 2009    Post subject: Reply with quote
if you fail part 1 you cant take part 2 but if you pass part 1 you only need to attempt part 2 from then on.
if you fail part 1 you have to wait 3 days before retesting whereas part 2 is a 10 day wait Exclamation
so glad i did the old style test! no messing about, get out on the road, do a u-turn and jobs a goodun Very Happy
bigbore
PostPosted: 10:27 - 30 Jun 2009    Post subject: Reply with quote
sorry to hear that but also a good lesson for you in the future
Never ever trust the orange flashing light of a car , as they lie .
I have been cut up many times in the past bloody car drivers Very Happy
gusto
PostPosted: 19:07 - 30 Jun 2009    Post subject: Re: mod 1 passed, mod 2 failed Reply with quote
I passed my mod 1 today, and snomag's advice really helped. I wanted to add a couple of extra points that helped me:
Hazard avoidance
Don't come off the throttle before you go through the speed trap (which I kept doing as I was practicing, and I lost speed too fast). Keep it quick in second gear and let off the throttle once you go through the speed trap. Remember to do your shoulder checks once you have stopped in the box after the swerve.
If you don't go through fast enough and you're asked to do it again, my instructor told me that you are allowed to ask the examiner how fast you were going, to give you a better idea for the second go - so if you were only 1 or 2mph off, you know you don't need to cane it and make that swerve harder on yourself. (Might be worth double checking this with your own instructor.)
As snomag said:
"check before you move off. Even when it's just the manual handling, look around, before you start wheeling the bike."
Yes! Look around before every start and after every stop.
By the way - I'm no expert, but these tips worked for me - if your instructor tells you different, then best to listen to them.
Mod 2 for me will be in a week - was gonna do it this week but decided to rest a bit and get some more road work in by myself.
schooleydoo
PostPosted: 11:30 - 01 Jul 2009    Post subject: Reply with quote
So for example, someone has passed module one and got their certificate, but failed module 2. They need to retake module 2. Will they have to pay the full test price or is it subsidised/split into mod1/2?
ThoughtContro...
PostPosted: 12:39 - 01 Jul 2009    Post subject: Reply with quote
The cost for mod1 is £10. Mod2 is £70.
If you fail mod2 you just pay another £70 for the second attempt, which must be a minimum of 10 working days after the last attempt.
If you were doing it with a school, then you'd have to pay for the extra half days bike hire as well.
ryhardcastle
PostPosted: 13:22 - 02 Jul 2009    Post subject: Reply with quote
Just come back from module 2 and I failed. Sad I failed because I was going slightly too fast in a 20mph zone (I didn't realise it was a 20 until it was too late, my fault really as I should have familiarised myself with the routes more)
It was 5 minutes into my test and the examiner told me to slow down. When she said that I knew I had failed and just wanted to go back to the test center Sad. I also got 2 minors for signals. Going to book a resit for 10 days time though.
Needless to say I am pretty gutted as I was going to buy an SV tomorrow.
Adrian
PostPosted: 15:05 - 02 Jul 2009    Post subject: Reply with quote
Unlucky mate, i failed my test on the exact same thing, the examiner didn't say anything though which made it even worse back at the test center as i was expecting a pass...passed third time, dont give up. Book a resit asap. Good luck Smile think about how much you want that SV Cool
snomag
PostPosted: 15:45 - 13 Jul 2009    Post subject: Reply with quote
Yay!
After having a 2weeks long holiday, I came back and got the second part of the test done. I'm pretty happy at the moment, but I can still hardly believe I got it.
When the examined started saying 'I am pleased to...' an amazinly weird grin appeared on my face, which's still there.
Think I'm going to have a few beers now to celebrate Very Happy.
Mark65
PostPosted: 16:00 - 13 Jul 2009    Post subject: Reply with quote
well done m8 Very Happy
brendan002
PostPosted: 16:55 - 13 Jul 2009    Post subject: Reply with quote
Well done mate, and congratulations on passing! Thumbs Up
08 Honda Hornet 600
The last post was made 17 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.8 - MySQL Queries: 16 - Page Size: 136.74 Kb
