cm250t custom
vorlon
PostPosted: 10:47 - 14 Apr 2024    Post subject: cm250t custom Reply with quote
i just bought this bike yesterday, wanted to get bsomething for the daily commute and this appeared on autotrader. i had one when they were new back in 1982. this is the same year and hasnt done 10k miles yet.
i drove it back the 70 miles and all was fine. stopped off to top the tank and then parked on the drive. the idea is to keep it parked at the side of the house behind a locked gate, so needed to move a few things. went back to the bike and it would not start and run. the throttle would not rev properly. tried it a couple of times. pushed it and parked it overnight. tried it again today and it does not want to catch at all.
now its been a while so i need pointers on where to start please.
i had thought that mabye i had accidently topped up with diesel(but i dont think so)
also should i be adding any kind of additive as the new fuel is so much different now
PostPosted: 10:53 - 14 Apr 2024    Post subject: Reply with quote
Back to basics. It's probably sat for a long time so there are a few things that could be going on. Contaminated fuel, blocked passageways, corroded connectors etc.
Check it has a spark. I'd give it new plugs unless you know they were done recently. Make sure the air filter is clean and useable, check in the tank with a torch for water/dirt/rust, check there's fuel flow out of the tap. Crack the float bown drains and see if fuel runs out, catch some and see if it's dirty/contaminated.
Remember the basics are fuel, air, spark and compression. If it's not running, one or more of those is missing.
It's a basic engine, shouldn't need additives. You might want to run it on E5 fuel though. Fuel hoses and internal seals in the carbs and fuel tap probably aren't ethanol safe. It wouldn't have cause any issues in this short a time though.
vorlon
PostPosted: 11:15 - 14 Apr 2024    Post subject: Reply with quote
thanks. well the guys who sold it to me said he'd serviced it, it also had a new battery and back tyre.
i'll check what i can . very odd that it should just stop like that though.
PostPosted: 13:07 - 14 Apr 2024    Post subject: Reply with quote
Don't believe anything a previous owner says with regard to servicing. That goes for both private sellers and dealers.
I'd say going for one long run then conking out and refusing to start is fairly usual for a bike that has been parked up for a protracted period of time. You give it just long enough to drag all the dirty, crappy fuel that was left in it through the tap and carbs. Any dried out seals and gaskets either plump up or fail and leak and the sparkplug bakes on any historic fouling.
PostPosted: 13:47 - 14 Apr 2024    Post subject: Reply with quote
I would also be suspicious of the need to replace the battery. Does the charging system work?
PostPosted: 14:26 - 14 Apr 2024    Post subject: Reply with quote
I'd agree on taking any previous 'servicing' with a pinch of salt and its always best to assume it hasn't been serviced and do it yourself.
Check you didn't accidentally leave the kill switch on STOP
Been there done that.
As its an AC CDI bike I'd do a stator test to check the
charge coils, source coils and pulser all check out AOK
jeffyjeff
PostPosted: 15:50 - 14 Apr 2024    Post subject: Reply with quote
WD Forte wrote:
...Check you didn't accidentally leave the kill switch on STOP
+1. Right. You usually don't find out until you've spent several hours (or days) dicking around, trying to find out why no start! Confused
Robby
Dirty Old Man
PostPosted: 16:13 - 14 Apr 2024    Post subject: Reply with quote
My first reaction would be water and/or rust in the carbs. Easy enough to check, drain the carbs into a cup using the drain screw, and look for anything in the cup that isn't petrol.
To do 10k miles in 42 years, it's spent a lot of that time not moving and quietly rusting.
PostPosted: 17:59 - 14 Apr 2024    Post subject: Reply with quote
Although with a CM, don't they self-excite? So if it turns over and there's a spark there, it would be safe to say there isn't an ignition problem?
PostPosted: 19:09 - 14 Apr 2024    Post subject: Reply with quote
No idea what the actual problem is, it could well be age related crap build up and residue for all we know.
Having had similar aged Hondas with AC CDI I'm assuming it's using the
same system
the source coils can break down when the charge coils are OK
and work/run but behave erratically as they warm up
I've known AC-CDI boxes to work well one minute than suddenly shit the bed with no warning.
This system shorts the source coil output to ground to stop the sparks
on both the ignition switch and kill switch
the kill switches especially could have build up of crud bridging the contacts
Hopefully it's just time and weather got in and it just needs
some detailed TLC
vorlon
PostPosted: 21:17 - 14 Apr 2024    Post subject: Reply with quote
wow, thanks guys. so i drained the bowls on each carb, r/h one had a tiny amount of bits in but otherwise clean. tank is also clean. checked the plugs, both were a little black. after a quick clean the both produced a spark, new plugs on order. still will not turn over, choke or not.
PostPosted: 22:29 - 14 Apr 2024    Post subject: Reply with quote
So it turns over and doesn't start or it doesn't turn over?
vorlon
PostPosted: 23:09 - 14 Apr 2024    Post subject: Reply with quote
turns over, sometimes sounds like it wants to, but does not catch.
oh and kill switch was the first thing i checked too, got burned before
PostPosted: 11:52 - 15 Apr 2024    Post subject: Reply with quote
Try it with jump cables.. Ignitors (TCIs and CDIs) need decent volts to make spark.
PostPosted: 14:01 - 15 Apr 2024    Post subject: Reply with quote
Are the plugs damp with petrol after trying to start the engine?
vorlon
PostPosted: 18:41 - 15 Apr 2024    Post subject: Reply with quote
so i put brand new plugs in and with the choke fully pulled out it finally came to life. however if i gave some throttle it would die. it got a little bettter after a while but not right. also gave all the electrics a squirt with wd40. then it started to rain so i came in.
jeffyjeff
PostPosted: 19:38 - 15 Apr 2024    Post subject: Reply with quote
I think you are probably going to have to disassemble those carburetors a little further than the float bowls. Remove the carburetors and clean thoroughly. Make sure the jets are clear, adjust the float height, and check needle valve operation. Check the condition of the rubber donuts between the carburetor and cylinder head. Air leaks here lean out your fuel mixture. The fuel petcock might have a filter in it or next to it; if so, make sure that it is not restricted.
PostPosted: 19:45 - 15 Apr 2024    Post subject: Reply with quote
It may well need a carb strip/clean but at that age I'd also check
the tank strainer amongst other stuff.
Does it have a manual or vac fuel tap?
BTW WD40 is ok as a water repellent but it's better to use switch cleaner in anything that has electrical contacts
vorlon
PostPosted: 22:59 - 15 Apr 2024    Post subject: Reply with quote
fuel tap is manual, where is the best place to get a carb kit from?
blurredman
PostPosted: 09:29 - 16 Apr 2024    Post subject: Reply with quote
As WD says. I have encountered this problem myself only recently. One day on my Suzki TS185 I was getting no idle after a little ride.. I just so happened to be on the way home so parked it up and left it. Then the next day I could barely start it. Eventually found that the Pulser coil was breaking down when warm. Replaced with a 2nd hand one and all was fine.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
vorlon
PostPosted: 21:58 - 17 Apr 2024    Post subject: Reply with quote
thought i'd post a pic. going to try to clean the carbs at the weekend
od pic wont attach
lingeringstin...
PostPosted: 22:57 - 18 Apr 2024    Post subject: Reply with quote
Sounds like a jet is blocked. It's fairly common on those carbs, especially after the bike had stood around for a while unused. I think the petrol evaporates out of the fuel bowl and the gunk residue then blocks the jets. I'm running near as dammit the same engine as that and spark is never an issue. If it doesn't want to start it's because a carb jet is gunked up. Luckily it's a quick and easy thing to put right with a can of tiger piss.
Robby
Dirty Old Man
PostPosted: 09:22 - 19 Apr 2024    Post subject: Reply with quote
NRP carbs - https://www.nrp-carbs.co.uk/
But I've found replacement main jet sizes in their kits to be a bit hit and miss. I replace most bits, but tend to keep and clean my original main jet.
PostPosted: 09:58 - 19 Apr 2024    Post subject: Reply with quote
In fairness, tiger piss isn't the strangest thing I've seen you run a bike on.
vorlon
PostPosted: 18:04 - 19 Apr 2024    Post subject: Reply with quote
so took the carbs off, cleaned all inside and checked all the jets were clear. put back on bike and it kinda started. needed choke for a while (although i may not have that right) but will not tick over properly and just stalls if i add throttle. the book said to alter the screw but that didnt really help much. what next?
oh, and i drained some of the fuel and looked in the tank. all clear.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.6 - MySQL Queries: 16 - Page Size: 131.98 Kb
