SYM XS125-K Vent line hanging and dripping fuel
CraddyMcPatty
PostPosted: 09:51 - 28 Apr 2024    Post subject: SYM XS125-K Vent line hanging and dripping fuel Reply with quote
So, just some context:
A month or so ago, I bought a 4-owner 2016 SYM XS125-K from a stranger to use as a beginner bike. It was poorly maintained and ran poorly. After a new chain kit, spark plug, oil and air filter, it runs well.
Long story short, someone had dismantled the SYM once before, and half-assed it when putting it back together, and that leads to (what I believe) a vent line hanging and leaking fuel everytime I make sudden movement (such as emergency braking) with a full/nearly full tank of fuel.
I have no clue where the line is supposed to go nor where it was before. Any help with these Chinese bikes?
PostPosted: 22:12 - 28 Apr 2024    Post subject: Reply with quote
For fuel tank vent/drain/breather pipes they just need to point down at the ground. Route them whatever way looks best without kinking the pipes and convoluted bends. Think about moving parts like the swing arm and whether they might mangle the pipes through their full range of travel.
PostPosted: 23:15 - 28 Apr 2024    Post subject: Reply with quote
You're overfilling you tank. The fuel goes into the vent at the top, it's location at the bottom is irrelevant. You don't want it to go in at the top.
CraddyMcPatty
PostPosted: 21:08 - 30 Apr 2024    Post subject: Reply with quote
Thank you for the advice, but pointing them at the ground would lead to just spitting fuel on the asphalt, as it does.
Routing the hose/line somewhere that looks alright and doesn't leak onto the ground, would most likely lead to fuel setting itself in the bottommost section of the hose/line, which could lead to complications later on, no?
Either way, appreciate the feedback and thanks a lot.
Thank your for the advice, I never really though about overfilling as I bought the bike with a full tank, but that could be the main reason. Thank you.
PostPosted: 22:36 - 30 Apr 2024    Post subject: Reply with quote
Just to expand on wot Nobby said any lines pretty much anywhere on a bike that have open ends are meant to drain excess liquids or gases - of course they're meant to hit the asphalt!
"But I don't want to lose all my petrol!" These lines will be coming from the top of the tank so no fuel should be spilling out unless either the bike's tipped over or the tank's been overfilled.
Evil Hans
PostPosted: 00:33 - 01 May 2024    Post subject: Reply with quote
That's the whole point of them. It stops the fuel from collecting anywhere on the bike and setting fire to you.
CraddyMcPatty
PostPosted: 00:40 - 01 May 2024    Post subject: Reply with quote
Oh alright, apologies for my misunderstanding. Thank you to both of you.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 51.82 Kb
