Engine STILL bogging down.
binge
Emo Kiddy
PostPosted: 12:30 - 15 Apr 2005    Post subject: Engine STILL bogging down. Reply with quote
Ok, over the last few weeks i've been trying to find out why my scooter is bogging down ans spluttering out when I go to pull away from the lights. I have to blip the throttle loads to get the revs to build up before it will pull away.
Now i've had:
New Spark plug
New drive belt
Cleaned carb out
New clutch
New rollers.
Any other ideas what it could be. My mixture is also bang on. (Brown plug)
<|Ben|>
killa
Won't Shut Up
PostPosted: 12:40 - 15 Apr 2005    Post subject: Reply with quote
2-stroke
Air Filter
Oil leak
Top/bottom end
Sorry, all I could think of for a Moped
binge
Emo Kiddy
PostPosted: 13:15 - 15 Apr 2005    Post subject: Reply with quote
Forgot to mention those.
About 1000 miles ago it had a full engine rebuild.
Last month I got a new K&N filter.
Yes it does have 2 stroke. Laughing
I don't think it has an oil leak. Rolling Eyes
<|Ben|>
bish777
PostPosted: 13:53 - 15 Apr 2005    Post subject: Reply with quote
Some sort of weird advance and retard problem? can you can get hold of another CDI? Check your timing gear to see if it hasnt moved?
GSXR1100J
Pat172
PostPosted: 20:59 - 15 Apr 2005    Post subject: Reply with quote
get a 125 Laughing
could be asmall air leak form anywhere, check the manifold as they can devolp cracks that are hard to see without looking closly
try sum gasket paste between the reed block and manifold
and check the reeds arnt chipped or slightly damaged, or worn through
- Suzuki Bandit N600
Kye
PostPosted: 21:06 - 15 Apr 2005    Post subject: Reply with quote
Might be your pilot system / needle, brown plug only really reflects you main jetting, not the pilot/needle
Ducati 600SS
Vespa PX125
Pat172
PostPosted: 21:07 - 15 Apr 2005    Post subject: Reply with quote
you can change the needle aswell to different thickness and grades - it all plays a role in the setting up of a carb, main jet, pilot jet, needle shape, attomiser, slide, idle screw and mixture
The last post was made 21 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 16 - Page Size: 53.53 Kb
