would a flat battery affect the idol on a 600
3806danny
PostPosted: 17:36 - 01 Jan 2006    Post subject: would a flat battery affect the idol on a 600 Reply with quote
i stoped at the lights the revs dropped a little then cut out,tryed starting but wouldnt have none of it pushed up the kerb waited a min then she started could it be the battery? cheers
sickpup
Old Timer
PostPosted: 17:42 - 01 Jan 2006    Post subject: Reply with quote
Could be so many things. What bike would be a start.
Waiting for omeone to say its carb icing Rolling Eyes
3806danny
PostPosted: 17:47 - 01 Jan 2006    Post subject: Reply with quote
its a bandit 600.it was running fine till it cut out at the lights and then wouldnt start for about 1minute,then it did,ive only had it 3 days
riichy
PostPosted: 18:08 - 01 Jan 2006    Post subject: Reply with quote
could be carb icing Wink .............. dose it bog down when you give it some gas, and dose the bike act like its out of petrol Question
.......... PLOD ............ zx636 2004
3806danny
PostPosted: 18:18 - 01 Jan 2006    Post subject: Reply with quote
when it was ticking over it seemed fine,its been idoling nicely till then as well?reved nice aswell,could cold air of done it?
loply
PostPosted: 18:35 - 01 Jan 2006    Post subject: Reply with quote
Ran out of petrol?
Yamaha SZR660 Caution to the wind, the throttle pinned!
3806danny
PostPosted: 18:41 - 01 Jan 2006    Post subject: Reply with quote
checked the tank seems ok ,cant believe it hasnt got a petrol gauge
Mongrel
PostPosted: 21:07 - 01 Jan 2006    Post subject: Reply with quote
What kind of idol is it?
Do you have a pop idol, or is it a movie idol... or a sporting idol... or just plain bone idol?? Mr. Green
3806danny
PostPosted: 21:10 - 01 Jan 2006    Post subject: Reply with quote
ha ha
Mongrel
PostPosted: 21:17 - 01 Jan 2006    Post subject: Reply with quote
Your idling problem could be carb icing but only if it was pretty cold.
Just as likely is a bad battery connection or earth, so have a good look at your electrics.
Is this the first time it's been a problem, if not what were the conditions like then?
GearboxGeezer
PostPosted: 21:20 - 01 Jan 2006    Post subject: Re: would a flat battery affect the idol on a 600 Reply with quote
MINE DOES THAT!! Sept I got a 50cc Peugeot XR6 Geared bike...
But I have had this trouble for ages and still cant find the problem, and the bike shop dosnt have a clue, really annoying as it cuts out within 15 mins, been ding it for months
riichy
PostPosted: 21:27 - 01 Jan 2006    Post subject: Reply with quote
the way to tell if its carb icing is to...... say from 4th gear blip down the gears untill you come to a stop. if its carb icing the revs will die on the blip like the motor is cutting out, then come alive when the clutch is out and its in say 3rd gear.....
if is carb icing... pull over some were safe, and tern the bike off, leave for about 1 min then tern on and let it warm up again should be fine now... also carb icing gets worse when you arse hole it in the cold so keep rev nice and smooth...
ok you can take this advice of leave it up to you.. some people
might think its wrong, but it what i have found to work
... Karma
riichy PM me for more info as my zxr400 is a bast at carb icing Laughing
3806danny
PostPosted: 21:28 - 01 Jan 2006    Post subject: Reply with quote
ive only had the bike 3 days and till then it ran fine its only done 14000 miles yeah it was cold but not freezing?
3806danny
PostPosted: 21:32 - 01 Jan 2006    Post subject: Reply with quote
yeah i went down the gears b4 i stoped then cut out wouldnt start on the spot had 2 wait,sounds right cheers
Mongrel
PostPosted: 21:44 - 01 Jan 2006    Post subject: Reply with quote
It doesn't need to be freezing to ice, you have wind chill etc helping out, Silkolene do a petrol additive which is well thought of on the Thundercat site, the 'cat suffers with icing too.
3806danny
PostPosted: 21:46 - 01 Jan 2006    Post subject: Reply with quote
where can i buy that stuff?
Mongrel
PostPosted: 21:54 - 01 Jan 2006    Post subject: Reply with quote
I use Silkolene FST and that seems to solve the problem of icing on my Cat
That was quoted from the site, it's available from Halfords etc.
The last post was made 20 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 96.31 Kb
