carb iceing
3806danny
PostPosted: 20:56 - 02 Jan 2006    Post subject: carb iceing Reply with quote
its happened twice now ,i cant find that sikolene pro-fst stuff,will redex work? Idea
3806danny
PostPosted: 21:01 - 02 Jan 2006    Post subject: Reply with quote
it has carb heaters but are they any good? Idea
sickpup
Old Timer
PostPosted: 21:20 - 02 Jan 2006    Post subject: Reply with quote
I know this may seem like a shock but are you sure it carb icing?
3806danny
PostPosted: 21:26 - 02 Jan 2006    Post subject: Reply with quote
its happened the dismorning and early yesterday,it cut out before a set of lights and after that the revs froze and cut out and had to 2 a couple of minutes b4 it started? will redex do any thing? cheers
PostPosted: 23:11 - 02 Jan 2006    Post subject: Reply with quote
Carb icing is not that common, and the weather is not exactly perfect for it, nor are you that likely to get it bimbling round at low speed. If heaters are fitted then the problem is even less likely (although the Kawasaki heaters have a filter in there which can get blocked).
Redex is unlikely to have any effect.
A more likely cause would be something like a blocked fuel tank breather.
strag
PostPosted: 23:37 - 02 Jan 2006    Post subject: Reply with quote
Wynn's dry fuel.
carbon bling
dodsi
Dirty Carny
PostPosted: 23:41 - 02 Jan 2006    Post subject: Reply with quote
My bandit never once carb iced.
The ZX does, but only done it once badly. Its just a trait of that bike.
Zimbo
PostPosted: 00:04 - 03 Jan 2006    Post subject: Reply with quote
Redex won't work I'm afraid.
Wynns Dry Fuel, however, will. Available in Halfords, purple bottle.
Good luck!
3806danny
PostPosted: 11:29 - 03 Jan 2006    Post subject: Reply with quote
i went halfords could'nt find nothing with carb iceing on it? does redex make the octane higher so harder to freeze?
PostPosted: 11:43 - 03 Jan 2006    Post subject: Reply with quote
No, redex does not increase the octane rating, and even if it did that would no affect carb icing.
Redex is mean to reduce carbon deposits in the engine. It is not designed to have any effect on carb icing.
If you are desperate try a VW dealer, as VW used to do an additive for use in the old beetle (presume they still sell it) as it was prone to icing.
However it is unlikely that what you are suffering from has any relation to carb icing. What makes you think it does?
3806danny
PostPosted: 17:44 - 03 Jan 2006    Post subject: Reply with quote
i got that pro fst stuff and the bike seems ok , thanks for every ones help
dodsi
Dirty Carny
PostPosted: 18:15 - 03 Jan 2006    Post subject: Reply with quote
aaaaah, The optimax effect.
The last post was made 20 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 74.95 Kb
