Derbi Senda 50cc water pump
nealsam
PostPosted: 20:01 - 09 Jun 2010    Post subject: Derbi Senda 50cc water pump Reply with quote
I Think the seal has gone on the water pump. I tried to remove it but it wont budge, is there a knack to it?
cheekythomas
PostPosted: 21:00 - 10 Jun 2010    Post subject: Reply with quote
No special technique, just unscrew the impeller, then push the shaft out of the case, then tap out the seals and replace with new.
Inspect the shaft for any wear or grooves where the seals fit, and replace if needed.. always fit a new impellor, they are dirt cheap.
Just watch out which waterpump kit you buy depending on the engine being used, the old engine had water pump above the oil pump, the new engine has it the other way round. Wink
The last post was made 14 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 30.71 Kb
