Author |
kramdra |
kramdra World Chat Champion
Back to top |
ThunderGuts |
ThunderGuts World Chat Champion
Posted: 12:31 - 25 Jun 2020 Post subject: |
These look OK if you've got clearance around frame/mudguards for 40mm tyres;
https://www.chainreactioncycles.com/schwalbe-smart-sam-performance-tyre/rp-prod171961
You could get away with a less aggressive tread if you're only on dry trails though (but even "dry" trails get muddy sometimes).
Hydraulics will require new brake levers and possibly gear shifters too if they're incorporated with the brake levers. I presume you're after more powerful braking and given you mention tending towards dry biking, I doubt fast pad wear is an issue for you (e.g. in muddy grit, where the self adjusting nature of hydraulics are handy). To be honest, v-brakes can be plenty powerful enough if properly set up with good quality pads (e.g. KoolStops) - I'd at least consider trying this first as it's not an expensive experiment plus you could probably transfer the pads to a hydraulic setup if you still find the performance inadequate. ____________________ TG. |
Back to top |
stinkwheel |
Back to top |
kramdra |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 21:00 - 25 Jun 2020 Post subject: |
Is this where I go "how wide's your rim?" fnarr, fnarr ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Nobby the Bastard |
Posted: 21:01 - 25 Jun 2020 Post subject: |
That headset spacer gap is shocking. I hope you didnt use threadlock on it.
Judging by the seat your piles must be like a bunch of grapes to need one like that. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Back to top |
Dave.... |
Dave.... Trackday Trickster
Back to top |
stinkwheel |
Posted: 22:36 - 25 Jun 2020 Post subject: |
Anyway. Try the tyres you have. You'll probably be surprised. Those will be fine on gravel/dry mud. I've taken my ridgid single speed road bike along several blue routes in the dry and did fine on it
What I'll warn you about right now though is if you try to go over stuff that's very rough and bumpy on 700c (eg, big roots), you'll either get your teeth rattled out of their sockets with 90psi in or loads of pinch flats.
You won't be able to fit a proper, high-profile MTB tyre to that, not enough clearance between the chainstays. 29"er tyres will fit on the 700c rims but when I did similar with a 700c cross country bike, even fitting a 29x 1.70 tyre I had to pinch the chainstay tubes.
I initially tried with 700c cyclocross tyres and they were plenty grippy but as soon as I hit rocks etc, they popped. Even when pumped right up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Ste |
Ste Not Work Safe
Posted: 22:38 - 25 Jun 2020 Post subject: |
Set those V brakes up properly.
The best cheap knobblies are whatever tyres are reduced by 50% or more for clearance purposes.
I don't /think/ your frame has disc brake mounts.
That saddle looks uncomfortable, has it got one of those foam cover things on it? |
Back to top |
stinkwheel |
Back to top |
ThunderGuts |
Back to top |
kramdra |
Back to top |
Easy-X |
Posted: 11:10 - 26 Jun 2020 Post subject: |
Need a few more photo angles but the clearances don't look like they suit fat knobblies. If you're happy with this as a road bike then are there any space/storage considerations that stop you from having a dedicated off-road bike?
Next door neighbour's kid had a similar bike and they stuck some knobblies on it (out of poverty rather than choice) and I noted they had entirely disconnected the front caliper to get it to fit! One for the Darwin awards
Otherwise, if you need to keep just a single bike, I think you might like some Schwalbe Marathon or Marathon Plus tyres:
https://www.sjscycles.co.uk/tyres-700c-622-rigid/
i.e. winter tyres, might get away with it. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
kramdra |
Back to top |
stinkwheel |
Posted: 15:41 - 02 Jul 2020 Post subject: |
The little hole is for the end of the return spring.
Some lever pins have a tiny little circlip inboard of the lever perch (between the lever and the perch).
Could do worse than one of on-ones Holdsworth saddles. Based on a classic Rolls/Turbo (each of which would cost more than this new in tatty, used condition). Classic "road" saddle. Just a nod to padding.
https://www.planetx.co.uk/i/q/SAHOGS/holdsworth-gran-sport-saddle
Their "bignose" is a more conventional MTB saddle though, again for £20.
I'm rocking a Dios Thronous saddle on my MTB but they are getting super expensive now. Effectively crocs for your arse. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
winz |
winz World Chat Champion
Posted: 16:14 - 02 Jul 2020 Post subject: |
They take me back to my old trails days 20 years ago! Had a set of those on my DMR Sidekick. ____________________ Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F |
Back to top |
kramdra |
Back to top |
Easy-X |
Back to top |
stinkwheel |
Back to top |
kramdra |
Posted: 00:21 - 03 Jul 2020 Post subject: |
Im happy with the wheel being off center, still rides and handles fine and there is clearance for a 45mm tyre.
I did not realise how much fuckery would be involved. Almost done I will trim the plastic, new downshift handle and epoxy any new holes, not that the shifter bit was in anyway sealed to begin with. The original brake lever pin was a 2 peice rivet, if anyone wondering I drilled it out before cutting the rest off.
https://i.postimg.cc/RVGFBqt0/IMG-20200702-225357.jpg
https://i.postimg.cc/63dW1Qwt/IMG-20200702-225413.jpg |
Back to top |
Easy-X |
Posted: 13:21 - 03 Jul 2020 Post subject: |
That always seemed to be a constant quest: finding separate levers and shifters that play nice together. And then when you get something that fits you realise you've totally n00bed out and got the wrong ratio on the gear pull
Regarding road tyres I used to find them fine on all but wet mud and slimy wood (like it goes when it's raining) so for fair weather riders it's not such a big deal. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
stinkwheel |
Back to top |
kramdra |
Posted: 22:27 - 06 Jul 2020 Post subject: |
I recently bought some MEK and so had a go at solvent welding some abs sheet to the shifter caps. Need a bit of sanding, epoxy and quick spray black but I am suprised how well it bonded. Angled up for gluing..
https://i.postimg.cc/zDMY2r9L/IMG-20200706-193705.jpg
https://i.postimg.cc/05fq12xv/IMG-20200707-192708.jpg
Good practise for the cbr6 fairings that I need to do next.
Also ordered a seat. 7 pound delivered from ebay china.
Back to top |
kramdra |
Back to top |
stinkwheel |
Posted: 12:21 - 16 Jul 2020 Post subject: |
Apparently the stuff shimano use is identical to the "green goo" hydrostatic fluid citroen use in their suspension in every respect but colour.
It's what I have in the wifes SLX brakes.
LHM fluid. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
The last post was made 3 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
