Author |
Trekblur456 |
Trekblur456 L Plate Warrior
Back to top |
mentalboy |
mentalboy World Chat Champion
Posted: 01:05 - 03 Jul 2020 Post subject: |
Welcome to BCF, the UK's largest motorcycle forum.
Luckily for you, we're an all inclusive bunch and even luckier we have a keen pedal pusher representation so you might be in luck with your question but not from me.
Edit: Ooh, another Floridaman. ____________________ Make mine a Corona. |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 13:26 - 03 Jul 2020 Post subject: |
The only thing that should happen with a bottom bracket is the bearings go. If you take the chain and cranks off you'd grab the axle then find some serious play or maybe even some clicking and clanking if really shot.
I say "should" as I have a feeling something else is going on ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
ThunderGuts |
Posted: 14:13 - 03 Jul 2020 Post subject: |
The bicycle frame functions like a listening stick, which is unhelpful as it means noises can appear to come from nowhere near where they're actually coming from. BB wouldn't cause a loss/skipping drive, BB failures usually are clunking or if they're really shot grating and/or wobbly cranks. There's not much to a bike's drive system, my guess is the freehub pawls might be gummed up and sticking, so not always consistently engaging with the teeth on the hub. With a few basic tools quite easy to look at, take the wheel out, cassette off (you'll probably need a tool for this, or take it to a bike shop and get them to whip it off for you while you wait as it'll only take moments) then carefully undo the retaining bolt (often an allen-head through the centre of the hub) to remove the freehub body. Take a look at the pawls; they should have the lightest film of oil (not grease) on them and the teeth should be clean. On an old bike, especially if it's been ham-fisted by someone (sticky pawls - pour grease in there and make it worse) or if the bearings have overfilled with grease and have squirted some into the freehub body, I wouldn't be surprised to find it a mess in there. If it is, clean it up thoroughly (use a solvent like petrol but be careful not to splash the bearings as you'll wash the grease out of them too) then give a SLIGHT oiling with a light oil like 3 in 1. Pop it back together and see how it is. It all sounds quite involved but if you've got the tools, the above takes about 10 minutes from start to finish.
While you're fixing your MTB, do your CBT and get a motorbike to ride around on in the meantime. ____________________ TG. |
Back to top |
Copycat73 |
Copycat73 World Chat Champion
Back to top |
mentalboy |
Back to top |
The last post was made 3 years, 341 days ago. Instead of replying here, would creating a new thread be more useful? |
