New biker at 48 advice please! !!
Bike Chat Forums Index -> New Bikers Goto page Previous  1, 2, 3
Zen Dog
PostPosted: 21:40 - 30 Jan 2022    Post subject: Reply with quote
trevor saxe-coburg-gotha wrote:
Hel do a de-linking kit for the bird - probably for the viffer to
Even ignoring jeffyjeff's potential liability issue, it's not as simple as ripping it out and adding in normal lines with a couple of blanking plates and loops or whatever unfortunately.
I did do some reading about it, but without getting into it too much, it's a pain. The master cylinders won't work very well, and the calipers will be a bit of a bodge, you're better off changing them really. And the left fork leg is setup for the weird extra master cylinder thing, so you need to change the fork lowers to fit other calipers. One approach some people do is fit everything from the fork lowers down from a Firestorm (a mod people do on the VFR750 for the better brakes too). Short version is, my brakes are good enough not to be worth the hassle of changing. It's just a system that adds weight and complexity to the bike for no discernible benefit.
Current - '94 VFR750FR, '00 VFR800FI Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
PostPosted: 21:51 - 30 Jan 2022    Post subject: Reply with quote
i'd forgotten all that bloody complication, yeah good points
chickenstrip
PostPosted: 15:36 - 31 Jan 2022    Post subject: Reply with quote
I'm still in two minds about ABS. I can think of one time when I crashed where ABS is likely to have prevented it.
But how does it do when you're having fun on your favourite twisty road, hard braking on the front into corners? Does it get intrusive under such circumstances?
I think the best thing would be to have ABS that you could switch off. Maybe have it be activated every time you switch on the ignition so you don't forget, but simply be able to hit a switch if you don't want it for whatever reason.
Of course the added expense on the price of a bike isn't welcome, so I also think it should be an optional extra.
Freddyfruitba...
PostPosted: 16:15 - 31 Jan 2022    Post subject: Reply with quote
Which is the exactly the scenario on my R1200RS - have never switched it off TBH.
A whole other issue is 'cornering ABS' (aka 'lean-angle sensitive ABS aka 'ABS Pro' or whatever. I'm pretty sure my own bike doesn't have it (I think it may have been available as a factory-fitted option?) but unlike with standard ABS I'm not about to test that any time soon! But I just can't imagine putting it to use in practice? When I managed to run off the edge of a fast bend one time, with expensive and painful consequences, it was so ingrained into me not to grab a handful of brake that even under those circumstances I didn't do so... if I were ever to do that again it's hard to picture myself overriding my instinct and jamming on the anchors.
The last post was made 2 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 43.47 Kb
