More scooty stuff
WD Forte
PostPosted: 20:11 - 14 May 2022    Post subject: More scooty stuff Reply with quote
It started with me not being able to get as comfy as I liked on the scooty
I looked up the cycle ergo page, dialled in the model and my height and saw this
https://imgur.com/m7lMfJG.jpg
Hmm.. yeah, all very well but I dont want to sit up and beg all the time
At times I want to put my feet forward (and feel the breeze on my lady bits..)
which makes me lean back a bit.
that didn't feel comfy and I figured I needed some kind of back rest
so jiggered about with the image
artists impression of initial idea:
https://imgur.com/eaNjnlz.jpg
I doubted I'd find an economical off the shelf device so rooted around my scrap pile for some 18mm external ply to make the back plate
https://imgur.com/y3XSjVI.jpg
and use some upcycled discarded steel tube to make the main support.
https://imgur.com/AEZHh2w.jpg
I had to make many experiments and tests to get it positioned so I could still lift the main seat whilst having something I could lean back on
The pad part
(30mm of camping mat covered with a strip cut off a waterproof boot liner)
is bolted to the base and can easily be removed for improving/upgrading the cover or adding extra padding should I need to.
https://imgur.com/LycOE2i.jpg
It feels pretty robust initially and will run it like this to see if any cunning wheezes to improve it present themselves
All made from stuff lying around the place.
Cost wise feck all apart from £10 for 100x 8mm nylock nuts and 100x 8mm washers
from Screwfix.
bikers smell of wee
PostPosted: 20:58 - 14 May 2022    Post subject: Reply with quote
You could fit a load of pike nuts on the back of it and modify it so it pivots down and locks over the seat as a theft deterrant.
bezzabsa
PostPosted: 15:55 - 16 May 2022    Post subject: Reply with quote
i was gunna use one of those Ab roller thingies as it already has a pad fitted to a sturdy frame...i'm 6 foot and the xv535 at the time was uncomfy until i slid over to almost on rear pad!!
blurredman
PostPosted: 21:47 - 16 May 2022    Post subject: Reply with quote
You never give people backies?
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
B1N
PostPosted: 22:01 - 16 May 2022    Post subject: Reply with quote
What about fronties instead then?
The last post was made 2 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 45.52 Kb
