Author |
A100man |
A100man World Chat Champion
Back to top |
stinkwheel |
Back to top |
stinkwheel |
Back to top |
struan80 |
struan80 World Chat Champion
Back to top |
stinkwheel |
Back to top |
struan80 |
Back to top |
A100man |
Posted: 11:29 - 22 Nov 2023 Post subject: |
stinkwheel wrote: |
Probably ride it to work and leave the work van there. It's a short commute but too long/steep/dangerous to cycle/walk (one bit is a single lane road with steep verges on a steep hill, it's not safe to pass a bike there but they all do anyway, it would be only a matter of time before someone took me out.). I considered an E-bike but this is way cheaper (even with all the work) and better. They have really good fuel consumption and I'll run it on castor 2t oil. A low revving air cooled 2t is a good choice for a short commute, not too fussy about being run up to temperature. It wouldn't do any of my other bikes any good being run like that.
A well reasoned justification
PS cases look mint - great job. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
stinkwheel |
Posted: 20:18 - 22 Nov 2023 Post subject: |
Back to top |
virus |
virus World Chat Champion
Posted: 20:24 - 22 Nov 2023 Post subject: |
that factory trials looks ace. deffo a win for old school side bowl carb too if the other one is that hefty. performance is adding lightness and all that.
stinkwheel wrote: |
Oh, and the plan is to go to the dragon rally on it next year, because Virus bet me a pint. |
Got my tickets confirmed for BP and the dragon. Also got a metzler karoo onto my spare rim for excess cause the sticky partworn track tyre I put on it to throw it up prescott hill climb this year is undoubtably shite in the cold and wet. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 13:04 - 23 Nov 2023 Post subject: |
Classic example of the downside of steel rims and tubed tyres. Damp gets in and then trapped behind two layers of rubber - tube & rim tape
On the DT, after treating the rust with the typical rust converter, I painted the valley of the rim with anti-corrosion enamel paint to try and head-off the same problem in the future. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
WD Forte |
WD Forte World Chat Champion
Posted: 16:35 - 23 Nov 2023 Post subject: |
I doubt the exact font will be that easy to find so briefly fecked about with the image to see about
cleaning it up to create a template for vinyl or decal.
https://imgur.com/85adFJq.jpg
then I looked online to see if there were any preexisting ones to save time
I didnt see any Motobeno ones so far but a Minsk
one is available
I kinda like them as it says 'muck'
https://mxg.one/shop/minsk-stickers-set/
https://mxg.one/wp-content/uploads/2020/06/28.005-MINSK-1.jpg
I see they'll also make them to your own design so if the
motobeno image was cleaned up and distortion/curvature removed you could probably get those made
My own preference would be to go for the commie bastard look ____________________ bikers smell of wee |
Back to top |
stinkwheel |
Posted: 17:30 - 23 Nov 2023 Post subject: |
It's going to be the Motobeno logo because a Motobeno with that exact dark blue tank with gold lettering was my first motorbike and the one I passed my test on.
I will be getting Як ты смееш! across the bottom of the numberplate which is Belarussian for "How dare you!". Given it runs on 25:1 premix. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Rob Fzs |
Rob Fzs World Chat Champion
Back to top |
stinkwheel |
Back to top |
blurredman |
Posted: 13:39 - 24 Nov 2023 Post subject: |
stinkwheel wrote: | Як ты смееш! |
As someone who can read cyrillic, I of course read this particular phrase in a Borat accent ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
stinkwheel |
Posted: 19:17 - 24 Nov 2023 Post subject: |
I considered silver solder. You can even just pre-assemble them then heat them with the MAPP torch. I've done it before by hammering the solder flat, coating in flux then wiring the joint together and heating away from the joint so the heat flows into it but it starts getting expensive. I don't think the oven would get hot enough even if the seat base would fit in.
Regarding a spanny, I'll probably fit the original exhaust at least initially. I had an idea that if I want a spanny, I'd fit an MZ TS125 exhaust. They are cheap and available and the engine dimensions are almost identical so the pressure waves should work. It would be in keeping with the origins of the bike as well as being the OG spanny designed by Walter Kaaden himself. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
stinkwheel |
Back to top |
A100man |
Posted: 18:34 - 25 Nov 2023 Post subject: |
With the welder have you tried clamping a block of brass behind the bit you're welding - should help prevent blow through. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
stinkwheel |
Posted: 22:44 - 25 Nov 2023 Post subject: |
Back to top |
Easy-X |
Posted: 02:07 - 26 Nov 2023 Post subject: |
I think the phrase is "best of a bad job" Square holes though, asking for trouble! ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
A100man |
Posted: 09:27 - 26 Nov 2023 Post subject: |
stinkwheel wrote: | Did the whole seat base with phosphopric acid to stabilise any rust.
Also been cleaning wheels, which is tedious and messy. |
Much easier once taken apart.. you could then get teh spokes re-plated if you wanted and even fit alloy rims ! ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
stinkwheel |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
stinkwheel |
Back to top |
