Hassling the Husky - Vitpilen 401 stuff
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2
Easy-X
PostPosted: 17:21 - 28 Oct 2023    Post subject: Reply with quote
Ribenapigeon wrote:
So a diet it is then.
How very dare you, sir, I resemble that remark!
There's also a thing called the "Svartpilen Weight Reduction Project" that I'm taking cues from...
You can drop something like the charcoal EVAP canister (it's to the left of the FuelX box in my pictures) - fuck the asthmatic kittens and all that - but it's all just plastic and rubber and hardly any weight to speak of. However, a lead-acid battery might be over 3kg and a Lithium Ion one less than 1kg with the added bonus of holding charge well if the bike's left sat a while. Sadly longer intervals for me, now I mostly work from home.
Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
Easy-X
PostPosted: 19:50 - 25 Nov 2023    Post subject: Reply with quote
After a month and a half of back & forth with KTM I finally got the handlebar kit sorted. (Top and bottom yokes now matching colours!)
As a reminder the Svartpilen (black arrow) is a "Street Scrambler" and the Vitpilen (white arrow) is a "Café Racer" Rolling Eyes Puke
https://pbs.twimg.com/media/Eq0pMHTXcAcBdPB.jpg:small
Apart from the obvious colour scheme differences they're essentially the same bike (and the same frame and engine as a Duke 390.) The physical differences are the handlebars, tyre choice and a tank bag mount, present only on the Svartpilen. I mostly zip into the City so stop-start traffic doesn't lend itself to the faux clip-ons hence the conversion.
First step is to survey the bike and make some notes on cable routing. For example, the clutch cable running behind an engine mount bracket:
https://i.imgur.com/cezuP1o.jpg
And the fork height:
https://i.imgur.com/biG0RdH.jpg
Then you just start stripping stuff off!
https://i.imgur.com/eHaDzZD.jpg
I removed the side/tank panels as precaution against tool scuffage. BTW managed to get the headlamp off still on its bracket so no need to adjust the beam angle later.
This is never a good look for a bike Smile
https://i.imgur.com/J50UrcL.jpg
The kit comes with new switches, clutch cable and brake pipe as the new handlebars raise things up a bit. Clutch cable? Dead easy. The other end from front brake lever where it goes to the top of the ABS unit? Complete c*nt to get to Sad
https://i.imgur.com/1RaoxxS.jpg
And no, you can't get to it from above Sad Fuck knows how they get this assembled at the factory.
New yokes are plain aluminium instead of the original anodised black:
https://i.imgur.com/ZZBF513.jpg
Everything routed in ready for the bracket that holds the dash display and headlamp:
https://i.imgur.com/4UDUJwj.jpg
Transition complete:
https://i.imgur.com/CM7soOU.jpg
Brake bleed was straightforward with one of those pipes with the one-way valve. Probably pissed away 200ml of DOT4 getting all the air bubbles out. (I'm not fretting over possible air in the ABS unit as the lower half of the system has not been touched.)
Not 100% sure about the new bar-end mirrors. They're a bit odd but then so is this bike!
https://i.imgur.com/It72SVa.jpg
As a bonus job I dicked about with my collection of end-cans and settled on this one:
https://i.imgur.com/sKzRsP1.jpg
Visually I think it suits the bike. Sans baffle the bike sounds like a hammer-drill, very unpleasant Sad The supplied baffle (which was more just a slight restriction) didn't do much to speak of. Then I tried this common sort you put in the end:
https://cdn.manomano.com/images/images_products/11790586/P/94156739_1.jpg
Slightly quieter but I didn't like the tone Thinking Then I tried this sort:
https://ae01.alicdn.com/kf/H7054d2fa8da64809b90681ef4e564b98Q.jpg_640x640Q90.jpg_.webp
Which sandwiches between the link pipe and the end-can. The result, audibly, was pretty good - not so loud you can't talk over it at idle but nice and meaty with some throttle. BTW I had the seat off while testing and there's a lovely induction note with the new air filters Smile
Hopefully the weather's not too bad tomorrow so I can give the bike a road test.
Easy-X
PostPosted: 16:01 - 28 Nov 2023    Post subject: Reply with quote
Work, work and more work Sad Only got out on the bike today.
The good news is the handlebars feel entirely natural. Hardly surprising but should also imply I've put the front end back together correctly Smile Brake is good, better if anything. Clutch needs no further adjustment.
The bad news: as the handlebars are higher and I have the fancy mirrors my bike cover doesn't fit as well. Stock mirrors would have been much worse though. Might actually go back to the round ones or seek out a different style.
Easy-X
PostPosted: 18:17 - 24 Feb 2024    Post subject: Reply with quote
In my continual quest for tonal quality I've refitted the original "sound damper box" midsection:
https://i.imgur.com/IAfRn8b.jpeg
Previously I had decat pipe > mid-section link pipe > end link pipe > end can (with baffle) and now it's decat pipe > box > end finisher. BTW the end is a ten dollar part meant for an MT10 Smile
Doesn't quite follow the lines of the bike:
https://i.imgur.com/AGshikN.jpeg
...but it gives the bike a simpler uncluttered look.
The previously arrangement made the bike sound like a dirt bike (big single, quelle surprise) which is fine if that's your thing but refitting the stock box has produced a much deeper note which I prefer.
In other news I went back to round bar-end mirrors for their convex nature.
Easy-X
PostPosted: 23:19 - 11 May 2024    Post subject: Reply with quote
Aesthetically pleasing as the previously pictured exhaust cut-off was and almost equally audibly pleasing when tearing about the place, one fatal flaw...
Bumbling in City traffic (which is the majority of my "in anger" use of the bike) it would hit a horrendous and unpleasant note around 3000~4000 rpm Sad So I've reverted to the previously pictured end-can but sans baffle.
It seems I will never again get remotely close to the musical nature of the CP2 engine. FML, First World Problems, etc.
Next project: sprocket change and/or new ECU to prioritise torque.
struan80
PostPosted: 00:28 - 12 May 2024    Post subject: Reply with quote
That exhaust! I'll bet it's good sound.
to v or not to v
PostPosted: 08:25 - 12 May 2024    Post subject: Reply with quote
so what is the bike like to ride.
is it fun, comfortable, are you left wanting a bit more power?
its old and fat, but its a damned good ride. the bikes not bad either.
Easy-X
PostPosted: 11:10 - 12 May 2024    Post subject: Reply with quote
In case you've missed me mention this elsewhere...
Bone stock the engine's Jekyll & Hyde. Under 6000rpm it's pretty anaemic but over that it turns into a bit of an animal. From what I've read "everybody knows" KTM has crippled later iterations to comply with emissions. Of course "cripple" really means only a couple of horses have gone missing but you know how people are on such topics Smile Essentially there's scope to take the 43~44bhp engine to 50+ which is quite a gain given the lightness of the bike.
As to riding it around it does feel like a pocket version of my XSR but somehow it doesn't seem as cramped as like wot my Rebel 500 was. Factory quick shift + throttle by wire translates to a fun transition from 0 to 60 Very Happy I also love the rear set pegs over the usual neutral mid-position found on most street bikes. Overall it just feels agile even though it's not particularly fast.
It's not up there with old-skool 250 2-stroke race bikes but I'd rate it as technically best of the bunch in the A2 segment right now. The Triumph 400 probably wins overall purely from style points Wink
WD Forte
PostPosted: 11:35 - 12 May 2024    Post subject: Reply with quote
Ha! Busted!
I spotted your crayons and using my forensic de editing skills
see you've been out there doing colouring in instead
of getting on with the work.
No wonder its taking so long
https://imgur.com/qUhYoV8.jpg[/img]
bikers smell of wee
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 67.88 Kb
