Author |
Visitor Q |
Visitor Q $25 whore
Posted: 19:00 - 14 Mar 2006 Post subject: Mini Fridges |
Right, i got a mahoosive minifridge just over a week ago.
It was making the odd funny noise. Usual fridge noises. Kinda like a whurr and then cork popping noises.
Thats not a problem.
The thing thats started to worry me a tad is its starting to sound like i have a hamster cage at the foot of my bed. Scratching, clicking, popping etc.
Now the only things i can think of, is not enough air space at the back (theres about an inch) or too much and crap is falling down it... ?
Anyone know any big no-nos with big fridges? Its not a shitty argos thing, its a proper bar sized stella beastie. Its about half a meter cube. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
Back to top |
greatmoorred |
greatmoorred Nearly there...
Back to top |
Visitor Q |
Visitor Q $25 whore
Back to top |
BFG |
BFG Brolly Dolly
Posted: 19:39 - 14 Mar 2006 Post subject: |
Our fridge complains with noise if it's not absolutely dead level front to back and side to side. |
Back to top |
it really is that quick |
it really is that quick Crazy Courier
Back to top |
Ste |
Ste Not Work Safe
Posted: 20:04 - 14 Mar 2006 Post subject: |
I've got a mini fridge thing, it makes noises like those a couple of times a day. Solution is to hit it. Hit it firmly on the top, couple of times with reasonable force and it's usually shutup.
If after hitting it a few times it's still making noise then try picking it up about a foot off the ground and dropping it.. Probably not very good for the fridge but if hitting it doesn't work the only thing available to try is dropping it.
Dunno if this is how you're meant to fix fridges but it works for me. |
Back to top |
NBO |
NBO Two Stroke Sniffer
Posted: 01:11 - 15 Mar 2006 Post subject: Re: Mini Fridges |
bonny_ricardo wrote: |
Anyone know any big no-nos with big fridges? Its not a shitty argos thing, its a proper bar sized stella beastie. Its about half a meter cube. |
Scratching, dunno. Maybe a fan motor or something locking in the compressor. pretty unlikely as it's new..
Clicking, if the fridge has poor air circulation around it or lots of crap has fallen down the back and is insulating the hot coil this will cause an increase in head pressure and temperature, as the head pressure rises so does the temperature of the compressor, the compressor has a thermal switch fitted to it, this switch will cut in and out as the body of the compressor rises above safe, click off, and when the temp reaches normal, it will click the compressor on. safety switch.
Popping noises, usually caused by liquid flood back. This is a term used when liquid refrigerant reaches the compressor, the liquid refrigerant will enter the compressor and mix with warm compressor oil, at this point a rapid state of change takes place from liquid to gas, this change of state can case a popping.
A few causes of liquid flood back, too much gas, badly sized expansion device, cold coil fan not working, hot coil fan not working, a lack of cooling around the hot coil/unit.
After saying that I have no idea exactly what fridge you have, if it's themorelectric the above is redundant. |
Back to top |
Visitor Q |
Visitor Q $25 whore
Back to top |
NBO |
Back to top |
TOM M |
TOM M World Chat Champion
Posted: 00:26 - 17 Mar 2006 Post subject: |
Ste wrote: | I've got a mini fridge thing, it makes noises like those a couple of times a day. Solution is to hit it. Hit it firmly on the top, couple of times with reasonable force and it's usually shutup.
Agree with this, ive got a mini fridge back at uni and it makes the exact same noises, when i hit the top of it they stop and it works fine again. ____________________ Now owner of a 1200 Bandit |
Back to top |
Kwaks |
Kwaks I'm not a fast rider
Posted: 18:55 - 17 Mar 2006 Post subject: |
As said before you should always leave a fridge to settle before powering up,we always recommended 6 hours to be safe ,swith it off for a while and it may be better when you start it up again. ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
Back to top |
Cillit-BANG |
Cillit-BANG World Chat Champion
Back to top |
Visitor Q |
Visitor Q $25 whore
Back to top |
The last post was made 18 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
